Question about Jet AFS-1000B Air Purifier
Runs but not for long and now the motor simply hums.
Hi, I have the same issues as others with my Jet Air Filtration system. What I did different was I hot wired the motor directly and it works just fine which focused the err on the PCB capacitor. Your explanation on fixing the PCB is wonderful but I have a question. You mention using a 1000F, 10V cap but the one I removed from the board is actually a 2200F, 10V one. Would you please explain why you used a 1000F one and is that the real fix? I ordered a 2200F one but now I'm wondering. Thanks in advance for your assistance! Mike
Posted by Mike on
  • Jet Master
  • 18,186 Answers
Stay with the one that you ordered. There is no variance allowed between 2200 uF and 1000. The voltage is the variance that you are allowed to change.
Posted on Dec 16, 2013
Testimonial: "Thanks Brad & that's what I thought but for some reason all fixes referenced a 1000microF capacitor not a 2200 microF one. Because mine is a 2200 that's what I ordered and will install. Do you know where I could possibly get a drawing showing the PCB cicuitry?"
What does it mean when the cleaning light is red?
It means that the corona wires require cleaning in order for the ionic filtration to again begin working (it is not filtering when the light is on).
Jul 09, 2014 | Sharper Image Ionic Breeze GP SI730 Air...
Tip
Sharper Imaage Ionizers
Ionized air purification systems have been proven to be ineffective for cleaning the air. These reports have been published by Consumer Reports as well as the EPA. Sharper Image filed a lawsuit against Consumer Reports and lost. They were ordered to pay Consumer Reports legal bills as well.
Sharper Image issued a recall on all Ionic Breeze Ionizers and filed for Chapter 11 at the same time.
Ionizers have been proven to create an ozone that is harmful to anyone with breathing problems.
Here is a link to the EPA report
Here is an article from CNN.com about The Sharp Image
Support for Ionic Breeze isn't possible since Shaper Image has recalled the product.
Your best bet to keep the air clean in your house is to use a hepa filtration system.
on Jul 12, 2008 | Sharper Image Professional Plus Ionic...
When bar light is on level 3 what does that mean holmes air purifier
Hello, this is Ava with Think Crucial.
There are 3 settings for optimum air filtration. You can operate your Holmes air purifier continuously on the Medium (2) setting. It's rugged motor has been designed to give many years of use. For quieter operation (such as bedroom), select the Low (1) setting. When high levels of air polution are present, select the HIGH (3) setting to quickly circulate and filter the room air.
You can purchase a wide variety of high quality Holmes replacement parts for your Holmes Air Purifier direct from Think Crucial with free shipping and an exclusive 10% coupon for Fixya.com readers, use code: FIXYA10
http://www.thinkcrucial.com/search?type=product&q=holmes
I hope this was helpful.
Ava B.
Think Crucial Customer Care
May 19, 2014 | Holmes Products HAP422-UC Air Purifier
Why would new fan motor blow the air backwards
Lmfao at Ken, dude this is a single phase 120 vac motor. You can close your eyes and pick one there is no switching of wires to the motor. YOur hot can go to which ever and your neutral can go to which ever. DOES NOT MATTER :-P don’t reply unless you know blow horn. But just a heads up you can Reverse rotation very easy...
Apr 29, 2014 | Alpine Air XL-15 Air Purifier
I have a F50E electronic filter. The light comes on, but there is no snapping sound when I push the test button. The cells and wires look ok. What could be the problem.
It's possible that the board is at fault. Triple check and make sure all the ionizing wires are in place on both cells and that the thin collector plates are not touching each other. Also, make sure the contact points are clean on both the cells and the cabinet.
The F50 is an obsolete EAC, so parts are becoming difficult to get. If the board is bad, I would recommend unplugging the unit and using a MERV 10 media filter in its place (Honeywell designed that EAC with the same cabinet as the media filter... all they did was add a power pack on top for the EAC. The media filter will slide directly in the cells place.) You will get better filtration with much less maintenance.
Mar 24, 2010 | Honeywell Air Purifiers
Fan motor making noise. Can I get a replacement fan?
If the "noise" is a fluttering sound (like fan blades are engaging housing or other internal structure), you need to trace this and clean or adjust it internally so it doesn't hit stuff. Cleaning it periodically (monthly) should be a given.
If the fan motor itself is grinding/losing a bearing, you will need to replace the motor. Note that there are different models/configurations for various models, you need the right one. I used to buy mine direct from EcoQuest, but they've changed owners in the last year, don't know if they still sell them as parts.
I think you can find motors on the Web, but you'll pay a premium price for single units, better to buy a used purifier off eBay/craigslist or find one at a garage sale, and cannibalize it.
I think I have one fan motor left in-stock (new); I can check to see if it's the right version if you want. I'd want $30 for it, plus shipping - you can likely do better than that if you're willing to hunt.
If I can be of further assistance, or if you have questions about any of my response(s), please let me know before rating me.
If this solves the issue, please rate it accordingly. My goal is to earn a "FixYa" rating from everyone I help.
Thanks for using Fixya.com,
Jon
Dec 02, 2009 | Alpine Air XL-15 Air Purifier
I have cleaned my unit but the red light stays on
Likely so these units usually put out ozone into the air in your home which is a known lung irritant. If you truly have indoor air quality issues the only way to properly attack it is through three steps
source control - what's causing it(uv lights to kill it usually)
ventilation - bring in fresh outdoor air and exhaust stale indoor air(ERVs and HRVs depending on your climate some dealers won't sell these if they don't offer it to you they are dumb find someone who does they are Recovery Ventilators)
filtration - a whole home filtration system (look to dealers who carry Lennox who is the only company with a 100% ozone free product line and the highest filtration rates available on the market "MERV 16" filters or Trane is ok as well as Carrier systems)
Sep 19, 2009 | Sharper Image Ionic Breeze GP SI730 Air...
Have missed placed my manual need to know how to clean. Now that I have taken it apart I cannot get it back together! Help!
These units usually put out ozone into the air in your home which is a known lung irritant. Sometimes they will call it an ionizer or something like that. If you truly have indoor air quality issues the only way to properly attack it is through three steps
You can look up the Lennox Merv 16 filter it was rated #1 in Consumer Reports december 2007 as the best whole home air filter above the trane clean effects and others. can be bought and installed for around 400 bucks to 1000 dependeing on how hard it is and ask about the pure air system if you want higher levels.
Sep 17, 2009 | Bionaire Air Purifiers
Squeek
Hi Wendie286,
I just answered your other posting which described a low "humming" sound. A squeak is different. Then it's very likely the motor. You could try a _very_ small/light application of oil to the shaft where it goes into the bearings, but that's probably a short-term fix.
If the unit is over 10 years old, the motor will probably need to be replaced at some point. Below is the relevant portion of my response in your other posting.
[fan motors]... are the only moving parts and do eventually wear-out. If it's still turning, it shouldn't be a problem - - if it starts turning slower and slower, it's time to plan a replacement motor. I have a couple, but I think FixYa's terms forbid me selling it to you directly. Recommended solutions in this case:
1) If you still know an active dealer, you might see if they have any, or if they know of a source (Ecoquest no longer supports them with spare parts).
2) You could probably find them on the web, though the last time I did this (in December), I couldn't seem to find them; I didn't have a lot of time to spend then.
3) Find another XL15 (maybe on eBay) and cannibalize a fan from the older machine (note: different versions of the XL15 had different motor mounting configurations, so me sure you know what you're getting - maybe ask for a digital picture of the prospective purchase showing how it's mounted).
If you write back with more details, I may be able to offer more precise guidance. If you want, I could try web-searching again.
If I can be of further assistance, or if you have questions, let me know before rating me.
Jon
Jan 18, 2009 | Alpine Air XL-15 Air Purifier
DOESN'T RUN ANYMORE
Check the capacitors. There are two to look for, one on the motor, the other on the PC controller board.
STEP ONE: Unplug the unit and support it on a table.
STEP TWO: remove the controller board from the exhaust side of the unit by unscrewing the screws holding the cover to the unit. Unplug the motor wire harness by pressing down on the white retaining clip. They go only one way, but it doesn’t hurt to note which is which.
STEP THREE: Unbolt the ground wire from the face plate and the whole board should come out. Unscrew the four screws holding the PC board. Look for a little foam pad that will drop out. Remember where to replace it. Screws and capacitor may have blue locktite on them.
STEP FOUR: Find the capacitor. It’s the part that looks like a tootsie roll, black with two wires coming out one side. It’s between the CPU chip and the big red square block. If it looks bloated, burnt or melted, you found the problem. Replace it with a 1000 microfarad (1000 uf/ 10 volt) ten volt capacitor with a radial lead. About $5 for the part at most electronic parts stores. Careful desoldering the old capacitor to avoid damaging the PC board. WATCH THE POLARITY. There is a negative and positive side. The negative side has a chevron (<) mark and is marked on the PC board. On mine the negative side was nearest the black micro chip and the positive side was towards the red JEFU MPE part. Use a little bolt-tite on the screws of the PC board and some on the capacitor on the PC board to limit vibration. Reinstall the board, plug it in and give it a whirl.
If no joy, STEP FIVE: Find the motor start capacitor. It is bolted near the motor, black about 1x 2 x 4 and has two red wires coming out of it. Take a battery operated resistance meter on a setting of R x 100 or higher. Charge the capacitor by connection one lead of the tester to one red wire and the other lead to the second red wire. You may have to strip the wire to make contact. Next reverse the leads and you should see the needle jump. Do it a third time incase the first try was discharging. If no needle jumping, replace capacitor. Couldn’t find this locally. May have to by directly from JET Tools. L
Recommend you hard crimp wire splices if cutting off the motor capacitor. .  You can check the windings on the motor too. Check for continuity between the white-yellow-blue-black wires of the motor harness. Any combination should work. If not, motor shot, time for some bigger bucks nrepair.
Hope this helps.
Jan 06, 2008 | Jet AFS-1000B Air Purifier
Jet AFS-1000B Air Purifier Logo
387 people viewed this question
Top Jet Air Purifiers Experts
Marvin
Marvin
Michael Youngman
Michael Youngman
Are you a Jet Air Purifier Expert? Answer questions, earn points and help others
