Ran obd scanner and got codes p0001 and p0300
SOURCE: what does code 42 mean
In your case you have direct ignition since your engine does not use a distributor. There is an ignition module that takes data from the cam and crank sensors to decide when to fire the coils.
There is a problem in the circuit of the module that manages spark timing. The module is what the coils are bolted to.
The module and harness would need to be tested, which requires a shop manual for the procedures.
Testimonial: "so if I replace both will that fix the problem instead of going to a shop for repairs"
