What to do
Dir- 600L has it's default IP as 192.168.0.xx it's gateway is 192.168.0.1, So u check your Pc's IP and Dedault gateway.
If u want to change ur Router IP, go to IE type http://192.168.1.1/
user name : admin
Password : Leave it Blank, means blank.
U can see the setting and controls of the Router. If u Know well about IP assigning den u can assing router IP. Best of Luck
SOURCE: can't configure dir-600 after enabling access point only
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.1.1
or
http://192.168.2.1
or
http://192.168.0.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
If you are still not able to access it with above ip then press RESET button for 10 seconds it is in back side of router.Then you can access it with 1 of the above ip.
Let me know if you need further assistance.
Thanks for using FixYa.
