Tomtom ONE 3rd Edition GPS Logo
J
Jeffrey Ward Wells Posted on Dec 16, 2013
How do i down load up dates i only have a cord for the car
I only have a car charger cord
TRINIDAD BROWN
Level 1:
New Friend:
Problem Solver:
  • Contributor 7 Answers
  • Posted on Dec 16, 2013
TRINIDAD BROWN
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
7
Questions
0
Helped
491
Points
12
Http://www.speedcamupdates.com/ONE-3rd-Edition
http://www.amazon.com/Edition-Charging-professional-outperforms-original/dp/9983764989
Here are the links you need to install your update for your 3rd edition. The other link is for the USB 2.0 Data Cable you need for your computer.
HOW TO HOOK UP A CTEK BATTERY CHARGER TO A 2007 MASERATI QUATTROPORTE SPORT GT
Wise decision my friend. Because with all the electronic stuff that's still running without the switch on, it can destroy a good battery after a while of non-use. A very, very slow drain. Just connect the hot wire directly to a lead directly to the battery and the ground to a bolt on the frame. Place the male end of the 110 cord where you can easily access it to plug it into the extension cord and wire tie it there. Mount the charger in an area where it can get air, under the hood on a fender well but out of the way. Because these new style chargers are "floating" chargers, it will shut down when battery is fully charged and restart with a 1% drop. Always remember to disconnect the extension cord from charger before starting the car. Otherwise you'll be replacing the charger. It's safe to hard wire the unit like this, no power goes back to the charger with the one way diode that's incorporated in the unit. Have fun with your toy.
Cigarette lighter doesn't accept charger
The cigarette lighter cannot afford to bear heavy loads. Attach the charger to battery directly with the provided cords.
My pmid705 wont charge for some reason and the battery is 35% the battery was just working yesterday (date March 20,2013
You have to check if the charger is still working fine. Check for any sign of power. You can also try removing the battery and use the charger in supplying the power to your computer, if it does not work then it's your power cord that's causing the problem and you might want to replace it.
1helpful
3answers
My compaq is power on for 2 second and off , how to fix is thank you
You need to print this out-on someone else's computer. Hope it works for you!
Remove the battery and charger/ac adapter/power cord from your Compaq Presario F700 laptop, press and hold the power button for 20 seconds to discharge any residual current inside the Compaq Presario F700 . This clears your RAM and is like a hardware reset. Replace the battery and charger/ac adapter/power cord and turn your Compaq Presario F700 laptop on.
Boot in "safe mode". As it starts up press F8, the computer ask you if you'd like to start in safe mode. Highlight "safe mode" and press enter. See if your laptop is booting up ok .
If your Compaq Presario F700 boots ok, do the following,
Try System Restore first,
Start Menu->All Programs->Accessories->System Tools->System Restore. Choose the most recent date before you the encountered problem. If it doesn't work, try the next date.
If System Restore does not fix it, as a last resort, you might need to fdisk, reformat your laptop hard disk clean and reinstall OS, that usually fixes all bugs. Before going that route, try following,
Uninstall unnecessary programs and applications.
Scan with a antivirus program
Scan with a spyware/malware program
DEFRAG C:
CHKDSK C:
Clean up and repair registry problems with registry repair software of your choice
If the problem persists, did you check if it could be your Compaq Presario F700 laptop power cord or power source problem? Defective or insufficient power supply might cause error messages that are misleading. Take the battery out and power on your laptop with the charger only. Make sure your Compaq Presario F700 power jack and charger plug tip are securely connected. Did you notice the power jack loose? You can find laptop power jack on ebay. Fixing and soldering the power jack requires professional skill though. The charger green/blue LED should be on. If not, replace the defective charger. Compaq Presario F700 laptop battery charger, especially its power cord/cable, lifespan is limited and does not last forever, consider buying a lifetime warranty charger online from company like www.topmic.com
Load beep when i plug charger into my gateway m675
I have two of the Gateway units and both do and did beep if on and power cord inserted---normal.
My Acer Aspire 5535 has stopped loading up.When it first started happening if you took the battery pack out for a bit and put it back it would load up and run for a while then shut back down . WHat can I...
I would say this is almost certainly a faulty charger. Ideally you should either test the charger if you have a voltmeter, or borrow a compatible charger to test. Once you have determined that it is the charger at fault you can replace it for less than £10/$15 (ebay for example).
Bought a kodak 763 camera at Sam's wholesale
whats the exact model of your camera?
when did you buy it? exact date of purchase?
2answers
How to install Garage cars into my Garmin nuvi 200w?
YES YOU NEED A usb MINI CORD 2.0 . iF YOU GO TO ANY STORE WHERE THEY SELL COMPUTERS THEY WILL HAVE IT JUST BRING YOUR GARMIN UNIT SO THEY CAN SEE THE TYPE PLUG YOU NEED. iT ALSO WORKS AS A CHARGER IF IT IS PLUGED INTO YOUR COMPUTER.
AFTER YOU HAVE THE CORD JUST PLUG INTO A USB PORT AND GOT TO THE GARMIN SITE. . THERE YOU CAN DOWN LOAD THE CARS FOR FREE iF YOU JUST PURCHASED YOUR GARMIN 200w THEN REGISTER IT THERE AND YOU WILL GET A FREE UP DATE TO THE MAPS . FREE FOR THE FIRST 90 DAYS. AFTER YOU REGISTER.
fyi IT TAKES A LONG TIME TO DOWN LOAD THE UPDATE. ABOUT 4HR ! THEN ANOTHER 1.5 HRS TO PUT IT INTO THE GARMIN UNIT.
Date display after down load, DSC-S650 Sony camera
you will not see the date and time on the thumbnail. look at the photo in full screen. make sure part of the photo is not "cropped" by checking to see if the arrows appear at the bottom and right. I bet the date & time is there, you are not seeing it.
Top Tomtom GPS Experts
k24674
Mike Cairns
Mike Cairns
Grand Canyon Tech
Grand Canyon Tech
Are you a Tomtom GPS Expert? Answer questions, earn points and help others
