A 1982 xj750 yamaha want charge what could be wrong
Hi have you checked the output from the alternator? This is 3 faze it has 3 yellow wires which connect to the rectifier, here the voltage is converted to dc used for charging the batery, check for broken wires from the alternator under the front sprocket cover, or corroded wires at the rectifier block connector, it is also important to have 12 volts in the battery to activate the charging process, using the machine with a pore condition battery can severley dammage the charging system componants
