Ive searched around some, and all i can come up with is 1.) Invalid ROM image detected. And.. 2.) BIOS or CMOS problem (ROM)Any Solutions? Ive been trying to figure this out for a month now =(
Hello,the only way to fix this problem is to prepare original bios file at your USB stick.But first you need to made this USB bootabile(put some universal BIOS fasher software from internet),than put the original file (bios)inside.when its finished try to find another PC (correct),pick up your BIOS chip,(the case of BIOS must be the same as another correct PC!!!!!!!!! IT IS VERY IMPORTANT),than turn on correct PC,run bios ,set USB stick as 1st bootabile device,save changes and restart PC,after that you will see universal Bios mask,you have choice to run bios file you already put on USB stick,DO NOT START FLASHING BIOS!!!!! PICK UP THIS BIOS CHIP FROM HIS CASE,THAN PUT YOUR BIOS CHIP (CHANGE CHIPS UNTIL THIS PC IS STILL WORKING)press enter and this PC will flash your BIOS with correct file.When its finished TURN OFF THIS PC(dont restart).Pick up your bios chip,and put it on your moterboard place for Bios,also put the bios chip from regular (correct)PC to its place,and you are finished.start PC you are using to fix problem ,just to check everything's OK,THAN TURN ON YOUR PC,IT MUST BE WORKING,9its look like risky job but dont worry its ok
I already fix lot of this problems,only check-dont short pins of chip,or turn chip at wrong direction,best luck :)
SOURCE: Screen displays no signal and then shuts off.
try a new power supply if still same result change the motherboard sorry thanks and good luck
SOURCE: BIOS ROM checksum error
sounds like your bios is corrupted, try going to the motherboard site and update your bios software. It could also be bad memory modules.
SOURCE: Changed out the motherboard reformatted a blank
Sounds like your BIOS update did not complete successfully. Head to the board manufacturers website and check if there is some way you can reload the BIOS and recover from this. Most boards now have dual bios which means that if one bios chip fails or an update fails, you can reload the stored BIOS through the other chip. If you are unable to recover from a failed BIOS update, you may need to purchase a replacement BIOS chip from the board manufacturer. You may even be able to reload the original BIOS onto the chip through your local PC repair store so give them a call and enquire..
Testimonial: "Information is quite accurate and on par.Appreciate the assistance.Downside for situation is a soldered bios chip.Thank you for your time and precise answer. "
AMI BIOS beep codes
Below are the AMI BIOS Beep codes that can occur. However, because of the wide variety of different computer manufacturers with this BIOS, the beep codes may vary.
Beep Code Descriptions Document
1 short DRAM refresh failure CH000996
2 short Parity circuit failure CH000607
3 short Base 64K RAM failure CH000996
4 short System timer failure CH000607
5 short Process failure CH000607
6 short Keyboard controller Gate A20 error CH000383
7 short Virtual mode exception error CH000607
8 short Display memory Read/Write test failure CH000607
9 short ROM BIOS checksum failure CH000607
10 short CMOS shutdown Read/Write error CH000239
11 short Cache Memory error CH000607
1 long, 3 short Conventional/Extended memory failure CH000996
1 long, 8 short Display/Retrace test failed CH000607
For more information go to: http://www.computerhope.com/beep.htm#04
