Try hooking up the dvd player and turning it on. Then use the setup and add/erase channel feature to look thru all of the channels. On my older GE tv I found that channel 91 was the correct channel for the video input. I saw the logo for the dvd player on this channel. I just added that channel and now it works. Your channel might be different.
Check the cable connections and/or replace the cables to the AV2 input.
If replacing the cable doesn't provide a solution, try running your DVD through the input. Since it works fine now, you would be checking the input AV2 by putting your working DVD. If the DVD plays with no problems, the input is fine.
Also try the VCR using coax into the TV instead of RCA into AV2. This will give you some idea about the condition of the VCR.
Make sure to switch the TV's tuner mode to Video or Aux mode.
You can change the mode using the original TV remote or directly from the TV's control panel.
Again, tuner mode picks up all live broadcast airwaves and Video or Auxillary mode displays what is inputed into the TV via second device..
On some sets you can use the menu button to enter the menu and navigate to the page which shows what input is currently selected and change it there. If your set does not have that option, then you will need the remote to do it. I have found that on some universal remotes, the TV/VCR button switches the inputs on the TV when the remote is in the TV mode. If that button does not work on your remote for your set, and you have tried all possible codes for JVC TVs, then the only way to switch inputs is to invest a few dollars more and get an original remote from JVC or have the set repaired so that the input button on the TV functions again.
