From information on other web sites regarding your model of electric percolator, the problem may lie with something in the electric base not working right.
If you have not already done so, I suggest you call Farberware Customer Service and ask for the name and location of an authorized Farberware repair service in your area, so that an authorized repair person can look at your percolator and determine what needs to be repaired (or replaced) and quote you a price.
This is the Farberware Customer Service phone number:
800-809-7166
Monday - Friday, 7:00 am - 5:00 pm (Pacific Time Zone)
This is the Farberware Customer Service phone number: 800-809-7166 Monday - Friday, 7:00 am - 5:00 pm (Pacific Time Zone)
USING YOUR PERCOLATOR
1.Wash the Percolator thoroughly before using for the first time.
(See "Cleaning Instructions" section in this manual.)
2.Remove Cover, Basket, Spreader and Pump Tube. Use cold, fresh
tap water to fill Percolator. Fill according to markings on inside
of Percolator for number of cups desired. Use cold tap water -
the automatic brewing cycle is timed to begin with a cold
water start.
NOTE: The bottom of the Pump Tube Spring marks the maximum
capacity of the Percolator.
3.Wet Coffee Basket to help keep small particles of coffee from sift-
ing through. Place Basket on Pump Tube. Add desired amount of
regular or percolator grind coffee to Basket.
4.Place Pump Tube with Basket into Percolator so bottom of tube is
set into Center Well. Place Spreader on top of Basket and snap
Cover onto Percolator. Attach cord to Percolator and plug into
standard household 120 volt AC wall outlet. Brewing begins
within seconds and continues at a cup-a-minute speed
5.When coffee brewing is complete, percolating will stop. The
Percolator automatically switches to "KEEP WARM" setting to
preserve fresh-tasting coffee at hot, ready-to-serve temperature.
For best flavor, remove Coffee Basket, Spreader and Pump Tube
when brewing is completed.
There is a thermostat in the bottom of the percolator that is broken. It would normally cut in to perc the coffee and then cut off the percolator heating element after the water reaches a certain temperature. It can be replaced but it takes a little skill. There is a video on eBay.
If you want to bypass the thermostat and just unplug the percolator, time it for 1 minute per cup.
First of all I have access to most parts.I can also make repairs or advise you to do it.I manufactured coffee urns and convection ovens for fsrberware. I also repaired 3 d different sizes of perks.reach m e a t [email protected] frank
I think it is because water goes through the coffee while it goes around and through the pipe inside the percolator Let the coffee stand for a few minutes when it is through, then .the coffee will be fine. enjoy your coffee kolbrun
