Question about Nordic Track NordicTrack Commercial 1500 Treadmill
Nordic track commercial zs stuck incline - Nordic Track NordicTrack Commercial 1500 Treadmill
5 Related Answers
Anonymous
  • 40 Answers
SOURCE: i have a nordic track a2350,and the incline wont
I've seen this problem several times, but many things can cause it. It's most likely the motor control board, but it could be a number of things. I'd have it looked at.
Posted on Oct 25, 2009
Anonymous
  • 40 Answers
SOURCE: the incline is frozen in about 6% inclination
Try calibrating the incline. That almost always fixes that problem.
Posted on Nov 01, 2009
Anonymous
  • 103 Answers
SOURCE: I have a nordic track a2350 and the belt stopped
This is usually related to the control pwb which is located under the motor "hood".
You can get this part from iconservice.com by going to the replacement parts section of the site and entering the model number of your machine, Which is located on the lower frame assembly below the walk belt. After you have receieved the part you can follow this procedure to repair it.
http://www.fixya.com/support/t3807308-belt_goes_full_speed_when_started_shuts
Posted on Jan 06, 2010
Anonymous
  • 12 Answers
SOURCE: I have a Nordic Track EXP1000i Treadmill. The
I know it's been months, but, if you still have this problem try this: 1. remove the philips screws holding the motor/belt/electronics cover on: you can lay the whole thing on it's side and remove them from the bottom. there's two in the front and two on the sides.
2. Obviously, unplug the unit! before doing anything. lay the unit back on it's feet (normal position)
3. Find the incline motor assembly. it will be int he middle of everything. black tube thingy.
4. take a cordless drill with a flat head screw driver bit, and turn the incline motor CCW. until the bed is flat.
5. what what I have read, you should shop for a new incline sensor. these fail before the motor does.
Posted on Jan 26, 2010
Anonymous
  • 12 Answers
SOURCE: I have a Nordic Track EXP 1000X treadmill and the
Probably 85% of the time, it's the sensor.
1. remove the screws from the bottom of the enclosure case. 2 or 3 in the front and 1 on each side
lay it back down, and power it up, and actuate your incline. watch the end of the motor, to see if the shaft is moving. It probably IS turning but only a little bit. NOT enough. In this case I'd say it is the sensor.
2. Unplug the unit of course.
3. the incline motor is in the middle of the pack,..you'll see a black tube looking thing sticking up.
4. on the bottom side of this, you will see,..or feel for a black square sensor attached to bottom of the motor casing.
5. follow the wires and unplug this.
6. pry it off with a screw driver. Remove incline assembly, if you cannot reach it.
7. replace sensor and try it again.
if the MOTOR does NOT turn when using the incline buttons, the problem backs up to possibly a bad control board. or a bad motor on your incliner, however, i'd say that's the last thing to go.
Order of failure: 1. sensor 2. control board 3. motor.
good luck
What is wrong with and how can I fix the incline on my Nordictrack commercial 1750 treadmill?
This sounds as though the motor is bad, they cost around $130.00, ther is a n electronic controller that controls it, but as it is trying to raise I would think that the switch and controller are functioning. Best of luck and please post back f this helps.
May 25, 2014 | Nordic Track Commercial 1750 Treadmill...
Oil lubricant belt
see the video and proceed according. lube the rollers bearing front+back too.
God bless you
Oct 23, 2013 | Nordic Track Nordictrack Commercial Zs...
Incline is stuck in the up position
LUBE the elevation motor: rack+pinion and the motor +try to adjust the POT see the picture+ diagram
However RUN the software calibration for diagnostic, troubleshooting, and fix it.
God bless you
Sep 29, 2012 | Nordic Track Nordictrack Commercial 1300...
My 1500 incline is stuck at 12% and won't respond to re-calibration
This is something you can fix yourself.
I suggest you get in contact with Icon Fitness.
Apr 04, 2011 | Nordic Track NordicTrack Commercial 1500...
My Nordictrack commercial 1500 is stuck at 12% incline and won't go nor up or down. How do i fix?
need to flip side and with a wrench 1 / 2 or 9 / 16 loosen the screw of motor base and try to press the down key and if so work you should Lift motor replacement
Sep 12, 2010 | Nordic Track NordicTrack Commercial 1500...
Does the Nordi Track Commercial zs Treadmill have a 3.0 CHP
It is continuous. Some manufacturers used to say just "horsepower," when "continuous" horsepower was really a better measure. Consumers picked up on this and started asking your question. Now the horsepower quoted by almost all brands, including NordicTrack, os continuous. However, they got lots of consumers asking "What does 'continuous' mean? so now they just say "horsepower," even though it is "continuous" horsepower! For a full explanation of what this means, see treadmill answers.
May 08, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track A2250 Pro stuck inclined
My Nordic Track Treadmill A2250 is stuck on the 12% incline position and it wont go back down and I have tried to reset it by turning it off, switching the reset button to off and then on or even unplugging it several times. What would be my next move?
Apr 05, 2010 | Nordic Track NordicTrack Treadmill, A2550
Nordic Track NordicTrack Commercial 1500 Treadmill Logo
476 people viewed this question
Top Nordic Track Exercise & Fitness Experts
Marvin
Marvin
Jesse Garza
Are you a Nordic Track Exercise and Fitnes Expert? Answer questions, earn points and help others
