Tv screen wont turn on just a green flash ontimer light
SOURCE: blinking green timer light
i have seen a couples mitsubishi and i all ready talked with a tech suport from mitsubishi but they said change the capacitors in the shop were i work we do the same but the tv still doing the same then we send the dm module to them and they fixed we asked whats the real problem and they said the capacitos the best i think is send the module to them
SOURCE: mitsubishi wd52527
does the light flash for 1 min then pause for a second then blink for another min?
SOURCE: Blinking Timer light on Mitsubishi WD62725
get a ohm meter and check all fuses ,and diodes they should all read 0. the ones do read something are bad replace them that means solder them out and back in
SOURCE: Mitsubishi TV green flashing timer light after power outage.
You will need to cahnge the capacitors on the DM board, very common problem. The V21 V19 DM repair kit at the following link contains the replacement capacitors and detailed instructions. Its listed under the repair kits catagory at the following link.
http://servicemanuals.vstore.ca/
SOURCE: Mitsubishi TV won't turn on green light flashing
Bad capacitor syndrome. Search 'bad caps' and model and you will find on goog.
