Konica 7415 erro code C14A3
When the Copier is switched on, it goes through its initialization routine, but stops with the message "Machine Trouble" and then "Service Call requires" with error code C14A3 in brackets.
Posted by FlashHammer on
  • scrnhiem Jul 16, 2008
    I have a Konica bizhub and the problem "machine trouble" is dsiplayed on the small screen of my copier. After this line is service call (C14A3). Please hepl me!
  • mohhusni2003 Jan 23, 2009
    I have the same problem c14a3
    please help me
    my e - mail : [email protected]
Scott Yeoman
  • 121 Answers
You have a blown exposure lamp or fuse. When repaired code will automaticaly reset.
Posted on Oct 18, 2007
Anonymous
Thanos0550.
Just cleaned the lamp and mirror and it work !
Posted on Jun 17, 2009
Anonymous
I had the same error on Di 1610 and i solved it by just cleaning the mirrors in the scanning unit.
Posted on Mar 25, 2008
Anonymous
I am having this problem too but where is the lamp and mirrirr ?\
please help me
Posted on Nov 07, 2009
How do i re-set fuser unit replacement message on bizhub c253
SIR/MAM
TROUBLE RESET
FIRST, If this code comes back. Have a technician look at it DO NOT CONTINUE TO RESET the code!!!! AS this is for the Hot Part called the FUSER. It can catch on fire! And that will ruin a perfectly good day!!!!
1. Turn OFF the main power switch.
2. Turn main power switch ON while pressing the Utility/Counter key.
3. Touch [Trouble Reset].
4. Check to make sure that [OK] is displayed and the it has been reset.
5. After turning off the main power switch, turn it on again more than 10 seconds after and check if the machine starts correctly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Jun 27, 2016 | Konica Minolta Bizhub C253 Copier
What can I do when my Konica Minolta bizhub 160 says machine trouble, service call (C14A3)
C14A3 means IR fluorescent lamp fault. Check the Exposure Lamp (LA2) . The Scanner Exposure Lamp fails to turn ON. Test the voltage supply & the Lamp.
Nov 04, 2014 | Konica Minolta bizhub Office Equipment &...
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
Jul 23, 2014 | Office Equipment & Supplies
Minolta 451 erro 3-b04
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit High Current Device for the fusing unit. Which will be expensive!!! Sorry :( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!! hope this helps
Oct 23, 2013 | Konica Minolta KONICA BR BIZHUB C451...
How to reset heating errors for konica minolta 420
Turn the main switch
Press Utility and then turn on the switch side
Press Reset Trouble
Power cycle the copier
Jun 22, 2011 | Konica Minolta Office Equipment & Supplies
C-3725 trouble code
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. It will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
May 18, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Error message c 3725 konica minolta c 550
Sir/Mam,
Turn off the main power switch located inside front door. Then holding down the utility/counter button turn the main power switch on. Close front door you must keep the utility button down also make sure that the sub power switch is on. This is the switch on the side of the control panel. The screen will show TROUBLE RESET touch it see OK then power off. YOU MUST WAIT TEN SECONDS BEFORE POWERING UP AGAIN!!!!!! If the problem goes away OK. If the code comes back you need a Fusing unit. Which will be expensive!!! Sorry:( DO NOT KEEP TRYING TO RESET THE MACHINE THE MACHINE IS TELLING YOU THERE IS A PROBLEM!!!!!
Mar 08, 2011 | Konica Minolta KONICA BR BIZHUB C451...
Minolta bizhub c 351 code c 3451
this error code means the fuser rollers failed to heat up you can reset the code by turning the machine off and hold down the utility\counter key while you turn the machine onwhen the trouble reset button shows on the touchscreen touch it and when it says ok turn the machine off then back on if the machine gives this erro again you will have to have the fuser replaced
Nov 19, 2009 | Konica Minolta bizhub C351 All-In-One...
Bizhub Di1610fp
C0500 code that is fuser.try reset this one first by powering machine on while holding down STOP BOTTON ON THE OP PANEL
hope that help
Oct 10, 2008 | Konica Minolta DiALTA Di200 Copier
Help! i get the "Machine Trouble" error
are you sure thats the right trouble code? reboot machine holding down the STOP button. this may reset this error
Dec 04, 2007 | Konica Minolta Di1610 Copier
1,968 people viewed this question
Marvin
Marvin
