It is just a standard Small Edison Screw (SES) appliance bulb. There is normally a removable cover on the exterior of the cabinet right behind where you can see the bulb on the inside. Remove the cover, unscrew the old bulb, install the new, replace the cover.
Pop the cover off. Remove the old bulb. Replace Bulb. Replace Cover.
Otherwise contact your local retailer directly or online here: http://www.keystonerv.com/contact-us
1. use old bulbs as samples by gently removing them with a soft cloth.2. Go to autopart shop or walmart,target or Canadian tire and you will find replacement bulbs. 3. Make sure you mark or place each old bulb into an envelope so you know where to put the new bulbs.
It is fairly simple to change your headlight bulb. First you need to buy a replacement bulb - typically the auto store will have a catalog with different models for your bulb. (Different brightness usually) My replacement bulb had the model 9004.
DO NOT TOUCH THE GLASS OF THE BULB WITH YOUR HANDS - the oil on your hands will cause the halogen bulb to burn out faster. You should be able to handle just the plastic part in the rear of the bulb.
Remove the old bulb (at the back of the headlight assembly) by twisting off the circular "cap" that keeps the bulb in. You can then detach the bulb socket and remove the old bulb. Insert the new bulb carefully and attach the bulb socket. Then twist the cap back on.
Open the truck & remove philips head screw that is located to the left of the tail light housing in the trunk lid weatherstripping housing area. Next unscrew the trunk lining screw to fold back the trunk lining to get at the two plastic wing nuts that hold the light housing.
Unscrew these two wing nuts and slide the housing out, then remove the bulbs and replace. Bulbs come out similarly to how you'd replace the front headlight bulbs (unplug, twist counter-clockwise to unlock and remove old bulb, replace with new bulb and turn clockwise to lock, plug back in).
you change the bulb from inside the engine compartment . raise the hood and feel for a plastic retaining ring in the back of the headlite. Loosen 1/4 turn and bulb socket and old bulb will pull out from the headlite assembly Unplug the old bulb and replace with new one . assemble in reverse order.
just like replacing a house light bulb. if it has a plastic cover, remove first the plastic cover and unscrew the old bulb and replaced it with a new one. unplugged it first before doing the bulb replacement. for safety...
first remove mains cord from main power. and remove the microwave oven top cover and check the bulb and crefully remove the old bulb and put new bulb. at high voltagae section dont touch any thing ,that area very dangerous ,thats why very carefully work inside the microwave oven ..
