I need step by step help to solve this problem. Oh, by the way, I'm running Windows XP on it.
SOURCE: Motion Computing C5 Tablet PC won't power on
Hi! I do understand that you are having the problem on the laptop turning on. Try another option, turn off laptop, remove cables and battery, press and hold power button for 10 secs. Reinsert the cables and battery on the laptop. Then turn it on. If the laptop did not turned on, remove the power cable and turned on the laptop. If still didn't, remove the battery and insert the power cable. If still did not work then check if there lights flashed on the laptop when turning it on. If still does not, then you need to contact the pc manufacturer for repair and possible replacement. Otherwise, if there is light on the laptop, then there might be a problem either the battery or the power cable itself. If there is light on the laptop but no power cable, most likely the monitor did not work simply because the battery works due to the fact that there is light on the laptop. On the other hand if there is light when plugging in the power cable on the laptop, then you need to check and insert another battery if it works. Otherwise you need to replace the battery...
SOURCE: I replaced the 30 G
Tried the same thing and got the same result using the motion computing DVD/CD external reader/burner.
Has anyone found an answer to this problem of trying to switch to a larger hard drive on the 1600 with format/installing? The new hard drive was not able to read the recovery disk with OS on it.
Thanks.
