Question about King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y
How do i remove the gear case on a lawn boy 55382
Posted by john boni on
Behind_Blue_Eyes
    Renaissance:
    An user who is expert in 3 categories / brands.
  • 1,727 Answers
Take the whole thing apart... Wow and I looked, thats ugly
Posted on Dec 28, 2013
How to remove and install a new drive belt on my 10641 lawn boy
Go to www.repairclinic.com and search for drive belt replacement information.
Aug 29, 2016 | Garden
How do you get the hub off to change the spindle seal? this is on a bad boy lawn mower 2300 series hydro gear, hydrolic driven zero turn mower?
Can you post a picture of the part you are trying to remove? Do you have a gear puller? It may be pressed on.
Aug 17, 2016 | Cars & Trucks
LAWN BOY 10323
just get started, one step at a time . inspect what needs tobe removed to get to that carb good luck.
Aug 17, 2014 | Briggs & Stratton Lawn-Boy 10640 20-Inch...
Self propelled lawn mower makes whinning noise
disconnect the spark plug turn the mower on its side and inspect the drive belt on the pulley above the blade (on the crankshaft) it may have a shroud over it. Also there is a small gear case that maybe dry that the belt drives, that goes to the wheels, Also try lifting the drive wheels up off the ground and engage them and see if it still does it. if it stops once lifted it might be the bushings on the axle its self.
Jul 19, 2014 | Briggs & Stratton Lawn-Boy Insight Series...
Why did my Lawn Boy Platinum self propelsion quit?
I believe there is a V-belt that drives the front wheels,it may have broken,or the gears in the gear box have failed !
Jun 22, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
Drive gear does not engage
Cable adjustment,broken V-belt, bad gear box.
May 30, 2014 | Tecumseh Lawn Boy Push Mowers Insight...
After about 15 to 30 minutes, engine starts pinging (for a few seconds) then dies
Not familiar with tecumseh lawn boy. Lawn boys I worked on were 2 stroke, if this is the case the crank seal is sucking air after engine warms up. New seal would fix. If you can't do it you're self may not be economically worth it.
Sep 28, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
The rear wheels will not turn in reverse at all. I
Rear wheel drives like this have pinion gears with rachet pawls that allow them to go backwards freely while locking when the transmission drives them.
You need to take off your rear wheels and carefully remove the pawls. They look like little squareish metal shaft keys with springs under them. You should notice that the keys or pawls are covered in what looks like grease.....which is actually worm metal from the pinion gear and oil mixed together to form this pastey greasey substance. Clean all that stuff off and lightly oil *( light oil...3 in 1 kind of oil) and reassemble.
You should hear the nice clean clicking of the rachet pawls as you roll backwards again!
Good luck and be careful!
Jun 22, 2010 | Tecumseh Lawn Boy Push Mowers Insight...
Free Online repair manual for Snow blower
No brake down on gear box for auger, part #740013 and its DISCONTINUED, belt # 700035
sheer pins 700104 , this was made in 1988 lawnboy bought gilson this was a gilson, many parts are
now discontinued .
Be careful when buying a new 2 stage there are many out there now that engines are made in china
even on Mtd, look for briggs or honda tecumseh went out this year .
good luck
Feb 01, 2009 | Garden
King Kutter II Gear Driven Rotary Tiller 6ft Tiller Width, Model No. Tg - 72 - Y Logo
94 people viewed this question
Top King Kutter Garden Experts
Charles Tidwell
Andrew Taylor
Andrew Taylor
john h
Are you a King Kutter Garden Expert? Answer questions, earn points and help others
