Oct 26, 2015 - My JBL Flip 2 is having some problems I turn it on and it all the lightsblink for a light ... I suspect it has to do with the bluetooth connection? .... Then, all of the sudden on the 2nd day, it will only stay on for about 2-3 minutes and ...
? 3:00
https://www.youtube.com/watch?v=9Nw8aXC3Gdk
Dec 22, 2012 - Uploaded by Kempton Lam
My JBL Flip 2 is having some problems I turn it on and it all the lights blink for a light then ... I suspect it has to do with the bluetooth connection?
www.jbl.com > Wireless > Portable Bluetooth Speakers
JBL
Rating: 3.5 - ‎270 reviews
Top Selling JBL Flip 2 rechargeable portable speaker features superior sound, ... JBL Flip 2 the wireless, portable, rechargeable battery powered speaker that is an all-terrain party you can carry in the palm of ...... Airforce1, do you mean registering the device with JBL or pairing? .... I have no sound or light from my speake
Hi there: Check this on 2004 Ford Explorer Sport Trac Audio Wiring Schematic:
Car Radio Battery Constant 12v+ Wire: Light Green Car Radio Accessory Switched 12v+ Wire: Yellow/Black Car Radio Ground Wire: Black Car Radio Illumination Wire: Light Blue/Red Car Stereo Dimmer Wire: N/A Car Stereo Power Antenna Trigger Wire: N/A Car Stereo Amp Turn-On Trigger Wire: N/A Car Stereo Amplifier Location: N/A Car Audio Front Tweeter Size: N/A Car Audio Front Tweeter Depth: N/A Car Audio Front Tweeter Location: N/A Left Front Speaker Positive Wire (+): Orange/Light Green Left Front Speaker Negative Wire (-): Light Blue/White Right Front Speaker Positive Wire (+): Dark Green/Orange Right Front Speaker Negative Wire (-): White/Light Green Car Audio Front Speakers Size: 6" x 8" Speakers Car Audio Front Speakers Depth: 2 1/2" Car Audio Front Speakers Location: N/A Left Rear Speaker Positive Wire (+): Gray/Light Blue Left Rear Speaker Negative Wire (-): Tan/Yellow Right Rear Speaker Positive Wire (+): Orange/Red Right Rear Speaker Negative Wire (-): Brown/Pink Car Audio Rear Speakers Size: 6" x 8" Speakers Car Audio Rear Speakers Depth: 3" Car Audio Rear Speakers Location: N/A Car Subwoofer Speaker Size: 8" Subwoofer Car Subwoofer Speaker Depth: 4" Car Subwoofer Speaker Location: N/A Car Subwoofer Speaker Positive Wire (+): N/A Car Subwoofer Speaker Negative Wire (-): N/A
Hope this helps; also keep in mind that your feedback is important and I`ll appreciate your time and consideration if you leave some testimonial comment about this answer.
Hi Roxanne
Sounds as though the power-supply might be faulty. As you turn up the volume more power is required from the supply and it's not delivering - hence the light fading.
Radio Constant 12V+ Wire: Orange Radio Switched 12V+ Wire: Yellow Radio Ground Wire: Black Radio Illumination Wire: Gray Radio Dimmer Wire: Brown Radio Power Antenna Trigger Wire: Pink Radio Amplifier Turn On Trigger Wire: N/A Front Speakers Size: 6 1/2′ Speakers Front Speakers Location: Doors Left Front Speaker Wire (+): Tan Left Front Speaker Wire (-): Gray Right Front Speaker Wire (+): Light Green Right Front Speaker Wire (-): Dark Green Rear Speakers Size: 6 1/2′ Speakers Rear Speakers Location: Side Panels Left Rear Speaker Wire (+): Brown Left Rear Speaker Wire (-): Yellow Right Rear Speaker Wire (+): Dark Blue Right Rear Speaker Wire (-): Light Blue
Hope this info helps please let me know if you need any further info
Here are some things to check for:
-Is the power on? There will be a light on the speakers that show it has power.
-Is the audio cable plugged in to the right spot? Most likely, the cable will need to be plugged in to a green colored jack on the back of your computer.
-Make sure the volume is turned up -- it's the knob on the speaker that you turn.
Try going to "control panel", then "sounds and audio devices" (in XP, should be the same in newer OS's). Click on the "advanced" button under Device Volume. That brings you to "volume control". Make sure the levels are up and the device is not muted.
Is the red light flashing at first?
The unit may be going into protect mode. Lets hope it has done the job and the receiver has protected itself from failure. Protect mode can result from speaker wires touching each other or the Amps metal case. Check that first. It can also be caused by unstable ohm loads if too many speakers are connected to any of the outputs especially zone 2. If you can remove all speaker wires and turn the unit back on. If it stays on, turn the volume down on the main zone and zone 2 if connected. Then reconnect speaker wires.
1. Check the light if it is lit on the speaker.
2. If you do not see any light lit on speaker, try to turn it on.
3. Check the speaker setup and connectivity.
4. Start>All Programs>Accessories>Entertainment>Volume Control
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
When I did this truck I had to go to the amp under the center console. Good luck
#510564: 2007 GMC SIERRA C1500 2DR TRUCK Audio/Mobile Video WIRE COLOR POLARITY LOCATION Battery ORANGE (+) RADIO HARNESS Accesory (CLASS 2 DATA) (+) RADIO HARNESS THE RADIO HARNESS DOES NOT PROVIDE A SWITCHED POWER SOURCE. RUN A WIRE TO THE FUSEBOX FOR SWITCHED POWER. THE ACCESSORY TURN-ON AND AMPLIFIER TURN-ON ARE CONTROLLED BY THE CLASS 2 SERIAL NETWORK. Ground BLACK/WHITE (-) RADIO HARNESS Illumination GRAY (+) RADIO HARNESS Dimmer BROWN (+) RADIO HARNESS Amp Turn On PINK (+) RADIO HARNESS LF Speaker (+) TAN LF Speaker (-) GRAY RF Speaker (+) LIGHT GREEN RF Speaker (-) DARK GREEN LR Speaker (+) BROWN LR Speaker (-) YELLOW RR Speaker (+) DARK BLUE RR Speaker (-) LIGHT BLUE Amp Location UNDER CENTER CONSOLE Steering Cntrls OPTIONAL THIS VEHICLE MAY BE EQUIPPED WITH OPTIONAL ONSTAR® TELEMATICS EQUIPMENT. USE AN APPROPRIATE INTEGRATION HARNESS OR INSTALLATION PROCEDURE TO ENSURE PROPER FUNCTION OF THIS EQUIPMENT. Speed Cntrl OPTIONAL Radio Security YES
