Where is the fuse holder located on a 2004 50 hp johnson outboard?
SOURCE: Have a 1980's 35 hp 2 cylinder Johnson Outboard
you will need a manuel . To set the advance you will have to get a old bent prop and cut the blades half off (test prop) back boat in lake on trailer,,,,, Or find a test tank ... Or hang on the back of the boat at wide open with someone driving and you hanging on with a timming light and watching flywheel
SOURCE: The starter will not engage to the flywheel on a
You may just have a weak battery, so get the one from your truck and see if that helps. If not get your jumpers and attach one to the negative and force it to have a new ground. Still nothing? take a pair of pliers and use the handles to arc across both big lugs on the starter solenoid. This may cause sparks --so no fuel nearby!! If that isn't doing it, you need a new starter, BUT try tapping the starter body with a big screwdriver handle first.
Sometimes the brushes are just stuck.
