I can record on the voice recorder. I can download the audio file from the SD card, but when I push the play button on the recorder nothing happens. I checked the speaker setting on the recorder and it is set to on.
SOURCE: Recordings play but skip every other second
you either don't have enough space on your computer for it to find the file and replay it(computers don't record in one solid track ,they take pieces and store them where ever they can.This is why its not good to defrag your comp. once you start a project) or you need to increase your buffer
SOURCE: Tascam Us144 and Sonar3 problem!!!!
Try this experiment: Record a click track on track #1. Record track #2 of the output of a monitor speaker playing track #1.
Now you have two click tracks which will probably not be cooincident (like they should be).
Measure the offset of the two tracks! You now know your latency exactly, and can compensate by adjusting settings or moving the vocal track back manually that many milliseconds!
SOURCE: I just switched computers to
It sounds like it maybe an asio problem or latencey issue. You need to increase the latencey in the control panel of your tascam soundcard and this should hopefully cure you .
