Question about Saeco Odea Giro Plus Coffee Maker
Hot water steamer does not work properly
The hot water steamer not working properly. Expresso works OK
Posted by Karl Street on
De Brewerz
    Habit-Forming:
    New Friend:
  • 17 Answers
Any coffee maker, espresso machine related sales-support issues you can always get in touch with www.De-Brewerz.com
Posted on Dec 16, 2013
4 Related Answers
bansheracer
  • 1089 Answers
SOURCE: steamer working only intermittendly
Hi
Have you tried to descale your machine. Remember to use the correct descaling powder and make sure that it is totally dissolved before running the descale program. In the menu, make sure that your water hardness is set on 4. descale more often than not enough.
Posted on May 24, 2009
bansheracer
  • 1089 Answers
SOURCE: The brew unit light is steady on and I cannot get
HI
Open the door and remove the dredge drawer, then the brew unit. Slide the brew unit back in , then push on the upper left side of the brew unit until it clicks. Close the door and push the dredge drawer back in with 1 finger on the right side of the dredge drawer. See if that worked. If it did, then loosen the nut behind the coffee dispenser to release tension on the brew group, then tighten again. Lube the receiver tip on the brew unit.
Posted on Nov 12, 2009
EsWorld
Ernest R
  • 1618 Answers
SOURCE: When I push the button
The water pressure is high possible because the grind is really fine, however water is not supposed to go through the valve unless it is open, you might have to replace the steam valve assembly.
Posted on Apr 25, 2011
Andy Turner
  • 910 Answers
SOURCE: When I try to use
Did you load the circuit prior to starting as detailed in the manual?
How long have you had this machine for and do you descale on a regular basis?
Posted on Jun 20, 2011
Delonghi stiromeglio master steamer iron , why no steam to the iron?
If you have been using tap water it may be plugged up with minerals.
Sep 13, 2014 | Coffee Makers & Espresso Machines
RE: F9 Upon startup the unit goes thru the normal cycles for making an expresso but, after the beans grind, little to nothiing is dispensed. The unit stops and the message is to fill water portion. I push...
Hi Bill
What happens when you do a tea ? (hot water only, NOT the steam button) do you also get little water ?
The fact that you are getting steam is good as there are 2 heating systems in the unit.
Have you ran the descaling recently (if you do not use filter ) ?
If you have or use a filter the problem is likely to be at the rear of the machine, however the back contents all the power and you will need to be happy to do some stripping down of the machine,
In the back you have the pump, valves, heater etc.
I am just about to draw up a flow chart of the water system inside the machine and have it published online (couple of days).
Are you happy to strip machine down ?
Please dont forget to vote if you liked my answer
thanks
Feb 12, 2011 | Jura Capresso Impressa F9 Espresso Machine
One side of the expresso machine is not working
Check the nozzle at the end of the steam wand, use a paperclip to clear, if you can get hot coffee then the steam wand is just blocked.
Oct 26, 2009 | Astoria Compact CKXE Espresso Machine
Leaking water from steamer
For the grouphead check the basket there might be a slight bump around the edge that is preventing it from making a good seal when it contacts the gasket in the head. If the Double works fine then the gasket is not the problem.
For the steam wand try flushing wand for 3 seconds just before steaming, if that does not help with the watery milk, then the boiler is not getting hot enough to produce steam.
May 18, 2009 | FrancisFrancis! X1 Espresso Machine
Too much water coming out of steam wand
I worked at StarBucks, what we did was put water into a contaner and steam the water, a lot of the time why the steamer doesn'..t work as well is because it is clogged. Another way to do it is to just run your steamer, also go to a coffee store and buy expresso machine cleaner. It could just need a good cleaning.
Apr 16, 2009 | Breville ESP8XL Espresso Machine
Don't know how to work the steamer.
I have the same Conair Cuisine Ultra expresso maker as you; its an old one. Make sure the coffee grind is in the spoon/filter cup and as the water heats it will brew the expresso. Simply twist the the knob at the top of the silver steam valve stem will let out hot steam for you to frosh the milk.
Nov 24, 2008 | Coffee Makers & Espresso Machines
No steam!
Ran into the same problem on mine just after using the steam, so it definetely wasn't clogged... hope this helps.
Just try running the expresso maker through a full cycle and then try the steam again. Not sure if the machine air locked or something, but the expresso cycle appeared to get the water flowing again and then it had no trouble producing steam.
Hope it works.
Jan 11, 2008 | Hamilton Beach 40729 Espresso Machine
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Isomac expresso machine
We have owned an Isomac Millenium for ~2y.
In the first months, we encountered low water to the brew head, although both the steam and hot water wands had decent pressure and flows.
Adjusting our grind, so that the coffee beans were coarser helped immensely--for awhile.
Then the problem gradually reappeared as an extremely slow brew time. Our machine was still relatively new, so we shipped it back to our place of purchase. It came back working just great and interestingly the filter in the resovoir was now filled with the filtering particulate it did not come with.
I am surmising, that however great the engineering is on the Isomac, manufacturing leaves something to be desired. Do not let your warranty expire. Pay the shipping and fix your otherwise great machine.
Nov 05, 2007 | Isomac Millenium Espresso Machine
Barista Coffee Expresso machine
yea, that happens to me. Try this way....Turn on the Barista, wait til the the steam's green light, then push the steamer button on, wait for a good 1 minute. It should be blowing hot air by then. Good Luck
Aug 22, 2007 | Starbucks Barista Utopia
Saeco Odea Giro Plus Coffee Maker Logo
235 people viewed this question
Top Saeco Coffee Makers & Espresso Machines Experts
ThaMp3Doctor
ThaMp3Doctor
Marvin
Marvin
Colin Stickland
Colin Stickland
Are you a Saeco Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
