Question about Insignia 32" 720p Flat-Panel LCD HDTV
Hi,model# ns-32d20sna14 tv,i have no sound on channel 7,the rest is fine. i checked the instruction and saw kabc 7 next to channel label,so what can i do? thank you. o.a.
This is all I have to say.
2 Related Answers
Jaime Hernandez
  • 2337 Answers
SOURCE: No picture, no sound, does light the insignia sign. Why?
In about 90% of the time the power supply is defective if the TV fails to power ON.
I repair these power supplies, if you need further assistance write to [email protected]
Posted on Jun 29, 2009
Anonymous
  • 32 Answers
SOURCE: INSIGNIA NS-LCD26A Model tv powers on with rainbow
if you check with multimeter, you know all worked fine, you need code programing of the tv, this code is for reconfiguring your tv, search by model, by device and brand, oh you need the remote control original, for solve this problem...
because the problem is programing electronic, the tv have a cpu and have a program, who can solve is expert electronic....
Posted on Mar 07, 2010
I have a INSIGNIA NS-32D20SNA14 32 led TV with only sound and a blue screen.
Check and replace the T'Con board. If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Jan 30, 2016 | Insignia Solutions NS-32D20SNA14 32" LED...
3 channels have no audio
The TV is set in wrong audio mode, probably SAP, go to menu and then adio and set it for standard audio mode or stereo. then it shoiuld work fine. If that don't work then unplug the set from the wall for 40 Min. and it will rest back to normal.
Jun 01, 2011 | Insignia NS-L322Q-10A LCD TV
Tv only gets lower channels
Go to settings manual, go to tuner mode, select CATV, than do an auto-programming or auto channel scan and you will be set.
Make sure it is not set to AIR
May 10, 2009 | Insignia NS-27 TV TV
No surround sound through tv
May be you have to set the Pro-logic option soundfield, this will matrix a 5.1 surround sound effect, unless of course you are sending a Dolby Digital 5.1 audio signal from your TV broadcast into the Home theatre system, also have to check the TV audio output to send audio output to a Home theatre system in other than 2 channel stereo.
Feb 09, 2009 | Insignia NS-H2002 Theater System
Programming channels
Hey abshee,
In order to program the channels for this TV, you'll want to press the "Menu" button on the TV itself. Once in the main menu, scroll down until you see an option called "Setup." From here, press the right arrow key to enter the submenu. Before going any further, you'll want to make sure that the tuning band is correctly set to "Air" or "Cable," which will depend on how you have your TV connected.
Once the proper input has been selected, you can then scroll down to "Auto Ch Search." If you press the right arrow key on this option, your TV will automatically search for all available channels.
If you'd like step-by-step instructions (with pictures of what you should see at any given step), I'd suggest checking out the link I've provided below to Insignia's online owner’s manual for this model:
http://www.insignia-products.com/skins/skin_1/Topics/Documents/NS-LCD22_press.pdf
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
Jun 19, 2008 | Televison & Video
TV changing channels
check channel up & down buttom if stuck up. if not, replace eeprom as possible. good luck!
Nov 27, 2007 | Insignia NS- 27" TV27 TV
Favourite setting lost when switched off
I think it is actually Channel 7 causing the problem. I have the same TV and have noticed that Ch7 only drops off the Favourites list when 7 telecasts a program in Standard Definition (SD) on the High Definition (HD) channel 70. They usually seem to do this when broadcasting sporting events. You can check if they're broadcasting in SD on the HD channel 70 by pressing the "INFO" key (also labelled "<<", just above the "TEXT" key). The channel description will read "70 7 SD Digital" instead of "70 7 HD Digital". (You will also see this when you change to channel 70 during these times.) Every time they've done this, I've lost the 7 HD channel from my favourites list. If you re-program channel 70 into your favourites list while it's broadcasting in SD, it will disappear from the favourites list when 7 starts broadcasting a HD signal again. I think I read somewhere that this happens because channel 7 isn't really transmitting a SD-resolution (576i) program on the HD channel, but instead just redirecting your TV to the SD channel's signal (Ch 7 on the tuner) - or something like that! I haven't yet found a way to stop this from happening other than to not change to HD channel 70 when they're telecasting a SD program! I have to admit, it's annoying, but it's a minor glitch in what I believe is an otherwise outstanding TV. I intend to email Network 7 about this problem. Maybe if the problem is their fault and enough people hassle them about it, they might do something to fix it! - Mav (Australia)
Jun 28, 2007 | LG 42PX5D 42 in. Plasma HDTV
Insignia 32" 720p Flat-Panel LCD HDTV Logo
37 people viewed this question
Top Insignia Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
