Question about Juicers
Breville emporia kettlr
How to remove base
Posted by arn9ie ultee on
Where could i get an instruction manual for a BJE400 Breville Juice fountain
https://www.breville.com.au/media/mediaappearance/2737/BJE410.pdf
Aug 18, 2016 | Breville Juicers
The wire basket of my Breville Juicer is rusted. is there a safe way to remove the rust or am I going to have to buy a new part? if it the the former, what should I use? if it is the latter, where can
I am not sure how rusted it is, but it should be fairly easy to clean.
I would start with either distilled white vinegar or fresh lemon juice. You should have good results with either.
Otherwise Breville does have an 800 number or just google the model number and part name, the part should be available.
Feb 13, 2015 | Breville Juicers
How do I fix my breville 5 speed juicer? The speeds wont adjust anymore. When i go to increase speed nothing happens unless i apply pressure to the knob, it then increases to speed5, and then goes bac
Your speed control is going out. I get parts like that all the time from a company called Allied Electronics. You will need to remove the speed control and get the part number off of it first before looking it up or calling.
Nov 13, 2014 | Breville Juicers
I have been given an Anthony Worral Thompson juicer by Breville byt and unable to get the mesh try out to clean it. How do I remove it?
Sep 23, 2011 | Breville JE3 Juicer
Replacement part needed
TRY 800 424 6783. PERSONALLY USING
A BREVILLE IS LIKE HANDLING A LOADED
WEAPON. MIGHT WANT TO CK OUT THE
OMEGA 4000.
May 06, 2009 | Juicers
Breville JE90J juice fountain spare part
The coupling on the juicer basket end is no big problem, but the coupling on the motor end is a big problem as you need to stop the motor from rotating to unscrew the coupling. This means remiving the base of the juicer which may be difficult because of the type of screws involved.
JE90/06 DRIVE COUPLING,
JE95/26 FILTER BASKET & DRIVE COUPLING
If you email me at [email protected] I can help you with prices etc.
Mar 28, 2009 | Breville JE3 Juicer
How do I remove the filer cone for cleaning?
I suggest pick it up by spout & other side of bowl & shake a little & it should release from the base unit
Jan 06, 2009 | Breville Juicers
Breville JE95XL juicer
I used needle nose pliers, it took a bit of patience but I got the screws out. I think I might replace them with regular screws. My juicer does not run either. Let me know if you find the problem with yours.
Dec 26, 2008 | Breville JE95XL Juicer
Juicers Logo
101 people viewed this question
Top Juicers Experts
Tom Chichester
ray gallant
Bill Boyd
Are you a Juicer Expert? Answer questions, earn points and help others
