Question about Bernina Activa 130
Bernina activa 210/how do i switch reverse sewing back to statight stitch
How do I change reverse sewing on bernina active 210 maschine to return to straight stitch
R.A. Ellis
  • Bernina Master
  • 12,731 Answers
Perhaps the manual would be helpful:
BERNINA activa 210 Support BERNINA
You may want to download and keep this manual. A lot of manuals for older Berninas are no longer available.
Posted on Jan 30, 2017
5 Related Answers
Anonymous
  • 619 Answers
SOURCE: Bernina Activa 135 sewing machine
Hi , the pedal micro switch are stuck , you may visit fixya repair service just , (enter zip area), you can find sewing machine repairman near you
Posted on Feb 22, 2008
Mimito7
Kelley Buchanan
  • 130 Answers
SOURCE: user manual download bernina activa 140 sewing machine
Try this... www.2instructions.com
Posted on Apr 30, 2009
ken dourof
  • 980 Answers
SOURCE: My Bernina 830 Sewing Machine is not sewing the
If you are selecting patterns but only getting a straight stitch after making sure you have set the width, there may be a chance that the pattern camstack has split and the selector finger is stuck in the split, more common than people think,
take the top off the machine and check
Posted on Oct 24, 2009
Anonymous
  • 9 Answers
SOURCE: I just purchased the Activa 210. There is a loud
Sounds like your zig zag stop is out of position, simple adjustment for a tech.
Posted on Aug 20, 2010
Tally Girl
Tally Girl
  • 1134 Answers
SOURCE: My bernina patchwork 140 will
Some machines will not do any of their automatic forwards and backwards movement type stitches in reverse, are you trying to reverse in straight stitch or a more complex stitch.
The Activa is a late model quality machine, do you have a Bernina dealer locally you could ring up and ask or take it to?
Posted on Mar 10, 2011
My Bernina 801 is stuck in the tack stitch. How do I get the regular stitch back??
Hm, am wondering if it is seizing. How long since it has had a thorough clean and oil? Seizing happens when the old oil dries and begins to stick the machine parts.
Wheel on right side that controls the needle up and down is very tight...
Dec 06, 2017 | Bernina Sewing Machines
Tip
Sewing Machines How do I make a zigzag stitch
When it comes time to do your actual project, you'll want to use thread that matches the color of your fabric.
  1. Step 1 Zigzag Stitch. ...
  2. Insert your fabric into the sewing machine and depress the presser foot. ...
  3. Guide the fabric through the machine to keep the stitch straight
Zigzag Stitch iFixit
How to Make Zigzag Stitch Sewing Machine
Bernina 550 40 Triple Straight Stitch Zig Zag
Zigzag foot 0
https://blog.bernina.com/en/2017/01/useful-stitches-are-also-decorative-stitches
Bernina Sewing Machines How do make zigzag stitch Google Search
on Dec 13, 2017 | Sewing Machines
My Bernina 830 will not switch stitches. It says the number but shows straight stitch and sews straight stitch
Is it a new 830 computerized model or the older 830 Record mechanical?
If it is the 830 Record, it needs oiling--1-2 drops of good quality sewing machine oil (specifically concentrate on the stitch selector lever and oil the metal parts that move against other metal parts) Do NOT oil the cams, plastic gears, any rubber parts, ie belts, bobbin winder wheel.
Bernina 530 through 830 Record Oiling Diagram
Oct 19, 2015 | Bernina Sewing Machines
Bernina activa 210 won't zigzag and has bobbin issues on straight stitch
it's very possible that the machine is slightly out of time & needs to be service at a sewing machine shop
is the fabric & thread & needle compatable with each other?
did you use every thread guide when threading the machine?
is the bobbin in correctly?
is the bobbin warped?
Mar 20, 2012 | Bernina Sewing Machines
Bernina 1080 while sewing normal stitch, stitch
What stitch to you have selected for it to do? Please check to see if it is set for straight stitch only.
Linda at Relics
www.sewing-machine-manuals.com
Jul 05, 2011 | Bernina Sewing Machines
My bernina patchwork 140 will not sew in reverse when I press the reverse button has the button gone bad the button hole won't sew ithe back stitch either?
Mar 10, 2011 | Bernina Activa 140
Ny bernina 1090 will only sew in reverse
My bernina did this too. Put your finger on the reverse stitch button, and keep it there for a few seconds. You have pressed the reverse stitch button too long, and it has gone into reverse mode. Hope this helps. tich
Oct 09, 2010 | Bernina 1008
When selecting the buttonhole option and starting the buttonhole the straight stitch reverse sewing doesn't happen after pressing the reverse button
It sounds like the feed block in the machine is sticking. This happens when the machine has been sitting for a time or not had much use. The old grease hardens slightly or "gums up" and the mechanism doesn't return easily to it correct position. A trip to your service tech would be your best bet.
Nov 11, 2009 | Bernina Virtuosa 150
Sewing Machines Logo
548 people viewed this question
Top Bernina Sewing Machines Experts
Chris Wetmore
Colin Stickland
Colin Stickland
Are you a Bernina Sewing Machine Expert? Answer questions, earn points and help others
