I think Splendide is still in business, in which case they may also be able to supply parts for the Bendix WDS 1043 M - check them out at http://www.splendide.com/
They can also supply a replacement washer/dryer combo when your present unit finally dies.
this sounds like a syphoning problem this means the outlet /drain pipe at the back of the machine has been pushed to far into the drain upstand pipe causing the water to syphon straight through the machine make sure that the drain pipe is only part way down the drain pipe, hope this works for you
The user manual is available here;
http://www.playstation.com/manual/pdf/PSP-1001K-2.7_1.pdf
goto page 102 (Theme Settings) and change the "Wallpaper" to off.
Hope this helps :)
p.s. the manual is for software version 2.70 which is the one previous to the latest. If your version has different theme menu, please ask again.
