Question about Kohler - Toilet - One-piece - Santa Rosa - K3323-52
Low water level in toilet bowl after flush
We have 3 Kohler Santa Rosa toilets. 2 are fine - but one has a very low water level in the toilet bowl after flushing. How do you increase the water level in the bowl. The water level in the toilet tank is just a little above the etched-in line on the tank.
5 Related Answers
Anonymous
  • 63 Answers
SOURCE: Master bath toilet replaced with a Cimmeron class
Kohler is correct. The most likely cause of this problem is an obstruction in the common vent stack that both toilets share. When you flush the old toilet it need more air to flush and will get it from the easiest source (your new water saver toilet). First adjust the float level in the old toilet so it won't use as much water or just stick a brick in the tank to take up space.Second, run a snake down the vent stack from the roof to check for obstructions. Birds will sometimes nest in there.
Posted on Mar 16, 2009
Anonymous
  • 146 Answers
SOURCE: Kohler Cimarron elongated comfort height toilet not flushing correctly
low water in the bowl is only caused by the float being to high! the gurgles is Usually because of air coming back up through the pipe, check your vent pipe that come out the roof. this will help the draining.
Posted on Jun 24, 2009
Anonymous
  • 2702 Answers
SOURCE: Can't adjust flush time for complete flush, low bowl water level
flush time depends on how much water is in it,
the water level flote has an adjuster on it, but i cant rember were it is,,, sorry
Posted on Oct 24, 2009
Anonymous
  • 5 Answers
SOURCE: Kohler welworth enlongated 2 piece toilet with
Place a few drops of food coloring in the tank of the toilet, if it is leaking you will see the color seep into the toilet bowl within a short period of time. If you see the food color in the toilet bowl you will need to replace the flapper.
Posted on Nov 14, 2009
EMSRSERVICEG
Lawrence Walters
  • 426 Answers
SOURCE: How do I adjust the
try turning the fill valve down
Posted on Dec 09, 2010
What is a flush cylinder
It is really the valve that opens up to let water flow through the bowl when activated by the flush lever, to flush the toilet. it should prohibit water from flowing after the toilet flushes.
Whine or squealing from tank when Kohler Santa Rosa toilet is flushed.
Sounds like an air lock is making the water fill in squeeze thru the piping. C if u can undo the piping from the tap below the tank and take out tank and try flushing the unit thru from the out side fill pipe. U may hv something stuck in the pipe line. cheers
1helpful
Kohler santa rosa fills, shuts off, a little water leaks from tank, toilet refills and repeats the leakage into the drain.
There is a rubber seal at the bottom of the flush valve that covers the openning at the bottom of the tank. If this rubber seal has perished slightly then it will leak water into the toilet bowl. This rubber seal need to be replaced to form a proper seal to prevent water leak.
Just bought and just had installed a Santa Rosa toilet that will not shut off when filling. Found flush valve filling chamber to have a triangular hole close to base of cylinder. when you cover this...
I would say yes....here is the .pdf for your toilet and it has nothing like that in it...your toilet should be a simple fill device and flush mechanisim...
I would return it for a new one...
http://www.us.kohler.com/onlinecatalog/pdf/1066506_2.pdf
heatman101
Water spits out of toilet bowl when toilet is flushed
If your referring to the tank, take the lid off and make sure the small tube is connected from the filler valve to the top of the overflow tube. If that's connected properly, flush the toilet with the tank top off and locate the source of the spray. A small crack in the fill valve can cause a significant spray.
How install Kohler part no. 87988 in Santa Rosa
look under the tank, their should be a nut holding on the old one. by removing that nut the part should free itself.
Toilet flushing sytem
your chain on your flapper is to long,adjust to proper hight.
Howto install an auto detergent dispenser onto existing toilet ci
"Fluidmaster" makes a device that clips onto the tank and dispenses a solution into the bowl at each fill after a flush.
It goes inline with the tube runing from the fill valve, and dumps into the flush valve which goes into the bowl when filling.
Most LOWES carries them.
These are better than the ones that release the chemical into the tank because the chemical never has a chance of causing corrosion and failure of the tank to bowl seals.
Kohler - Toilet - One-piece - Santa Rosa - K3323-52 Logo
Top Kohler Home Experts
john h
Tim Whalen
Mike
Are you a Kohler Home Expert? Answer questions, earn points and help others
