I have to input my pin number on my blackberry 8310 everytime I get into the car to connect with the cars parrot bluetooth device. It used to auto connect then I changed some settings and now can not get this facility back. I have tried everything under the blackberry phones bluetooth settings but no luck - Help - Thanks.
SOURCE: Blackberry 8310 Bluetooth device no services
I just experieiced this for the second time on my 8320 using a plantronics 510 bluetooth. The solution was to take the battery adn SIM card out of the phoine and leave it out for a full minute. It appears that the phone needs to be rebooted once in a while. I suspect Bill Gates designed some of the internal code.
SOURCE: Bluetooth
Your bluetooth needs to be in pairing mode. Depending on what model bluetooth there are several methods to put it in pairing mode. the most common is pushing and holding the main button until a light changes color.
SOURCE: Blackberry 8310 will not sink with computer. plug
Try a different usb port even another computer to see if its your phone or the computer. if you have no luck you can try the jl commander option to wipe your phone and then try to reconnect it but this will lose any un backed up data. Also look in the usb port and see if any of the prongs look bent pushed out of place or missing. if this is the case the phones only chance to connect is via bluetooth
If desktop manager will not recognize your phone then download JL commander (google search it) and select the wipe option then try again.
SOURCE: Remote funtions on LG HBS200 do not work with Blackberry Tour
When you go into the Tour's Bluetooth options, you can view which services are available for each paired device. Check the headset's properties and make sure all of the available services have a check mark next to them.
If that doesn't solve the problem, let me know and we'll try to find another solution.
SOURCE: My Blackberry 8310 finds the
The generic PIN (Which is what I'm guessing you need) for most bluetooth devices is either 0000, or 1234. Please try those and see if that solves your problem.
