Question about Rustoleum 224284 10.25OZ Rust Inhibitor Rust-O-Leum
Painting on top of 224284 Rust Inhibitor - Rustoleum 224284 10.25OZ Rust Inhibitor Rust-O-Leum
Rouand Sido
    New Friend:
  • 6 Answers
The product data sheets states that:
PAINTING If surfaces are to be painted in the future, remove Rust Inhibitor from the surface with a solvent such as acetone or mineral spirits prior to painting.
Posted on May 05, 2015
Our white refrigerator has some rust on the outside. There is also rust behind our kitchen faucet. How do we fix this?
need to wipe the moisture off so it doesn't sit on fixtures 2 ways of taking care of rust clean it than wipe down with a rust inhibitor sand smooth to metal spray primer than respray with white appliance paint or if to much rust/damage order new door front--- on faucet clean and polish should clean up unit if not and flaking alot possible may need to replace faucet
Aug 12, 2016 | Plumbing
How do I repair the bubbles on the exterior of my 1992 georgie boy cruise air 111
paint , if that is what has bubbled, needs to be taken back to metal with sandpape. Only the affected areas should be rubbed down to the metal. When this is fone rust inhibitor should be painted onto th affacted areas. some axide paint should be appled as an undercoat, exide primer that is, two or three coats . .If there are any pits use some filler and rub this down prior to spplying the primer.. The primer should be slightly below the surrounding paint before the application of top coat. the treated are should be wiped down with isopropyl to remove dust etc. then the top coat should be applied and allowed to dry for a week befor being touched
Jun 03, 2015 | Cars & Trucks
How do I fix extensive rusting under my 2003 nissan pathfinder, I am really worried, please what do I do?
There is a paint on rust converter . You paint it on the rust and it turns it back into metal . After that i would spray the rubberized under coating to protect it.
Nov 19, 2014 | 2003 Nissan Pathfinder
How can I help clean the rust from the bottom of my ford windstar 2003?
Scrape off the rust, using a wire brush or scrubbing pad. This technique removes small rust. GM MDI
Apply a rust remover, using a steel wool pad or paper towel. Rub the rust remover into the rust.
Wait 10 minutes for the rust remover to work. Most rust removers contain hydrochloric acid, oxalic acid or other strong acids that dissolve rust.
Clean away the rust remover and the rust with paper towels. Dampen a paper towel, and wipe the areas, again.
Paint on a primer with a paint brush. Let the primer dry. The automotive primers offer protection against rust.
Use touch-up paint that is the same color as the Ford Galaxie. Apply it to all areas that are missing paint. Let the paint dry, before driving the car.
Sep 15, 2014 | Cars & Trucks
How to remove rust off car
I suggest to use Rust Bullet, it is a very good rust inhibitor with lots of good reviews. I have utilized it on my car and never had rust problems again.
You can check the below link for the automotive kit:
https://www.rustbullet.com/products/automotive.html
Rust Inhibitor Paint to stop rust and rust repair Stop Rust Permanatley...
Jun 06, 2014 | Buick Regal Cars & Trucks
How do I remove rust from a car
Suggest naval jelly. It will damage the paint that it touches but will remove the rust. Apply according to the directions on the bottle.
May 16, 2014 | Cars & Trucks
Is it possible to paint over my grandmothers old wrought iron bed frame? It is in great condition and the size is right, I would just rather something a little brighter.
You need to buy a special paint for metal with special additives that prevent rust. Make sure to also buy a primer that is compatible with the paint you have selected. I found you some great instructions that should help you out.
Wipe the wrought-iron bed frames with a rag that was dipped in mineral spirits. That will help you to remove all traces of oil and grease from the frames.
Scrape rusty areas with a putty knife or scraping tool. Remove all loose rust scale. Rub the surface with steel wool, too.
Apply an oil-based primer. The primer needs to be designed for use on metal surfaces such as wrought iron. Roll on the primer with a small roller. Spread the primer with a paintbrush. Cover the whole surface with one coat of primer.
Paint the bed frames with a finish paint that has a rust inhibitor within 24 hours of priming them. That will help the primer and paint bond.
Roll on the paint in the same way you applied the primer. Use a paintbrush to make smooth, sweeping strokes to distribute the paint. Switch to a paintbrush with synthetic bristles if you decide to use a water-based paint.
Read more:
How to Paint Wrought Iron Bed Frames ' eHow.com http://www.ehow.com/how_7794293_paint-wrought-iron-bed-frames.html#ixzz232Q8GYhr
Aug 16, 2012 | Furniture
A deep rust spot through teh top of the front window frame What is the best and least costly repair for this considerig it is a 1991 model?
I would just use silicone on it, clean it as best as you can and sand it so the silicone will stick you could use a two part epoxy but epoxy gets hard and won't flex causing it to break when the top expands with air being hot and cold. Once the rust starts it's hard to stop, you can buy some Navel Jelly it's a rust inhibitor that will turn rust to a dark color then can be cleaned and painted over and if you want to paint it afterwords you can get the matching paint at Toyota dealer cost about $10.00 for the touch up paint. Hope this helps.
Jan 22, 2010 | 1991 Toyota Corolla
Hello i have a problem with my microwave I used an abrasive cleaner on bottom of microwave under the turntable it has now started to rust at this stage surface rust only is it repairable
Yes you can, it is a painted surface correct? If so buy some rust inhibitor spay or primer and spary the bottom and then paint. Make sure you tape off any vents on the bottom before you do anything
Oct 01, 2009 | Microwave Ovens
RUST ON DOOR OF FRIDGE
Check out this site
www.applianceart.com
these guys sell covers for your fridge and ones to match your other appliances. These are vinyl and magnetic covers which are so much easier than paint. Again, so much easier and neater than paint and the effect is better. They even have stainless steel. I hope this helps you.
Jun 04, 2009 | Whirlpool ET8CHEXSQ Dryer
Rustoleum 224284 10.25OZ Rust Inhibitor Rust-O-Leum Logo
193 people viewed this question
Top Rustoleum Tools & Hardware - Others Experts
Marvin
Marvin
john h
Andrew Taylor
Andrew Taylor
Are you a Rustoleum Tool and Hardware - Other Expert? Answer questions, earn points and help others
