Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb Logo
A
Anonymous Posted on Dec 14, 2013
On model el8807 the hose has no suction - Electrolux EL8807A Precision BrushRoll Clean. Bagless Upright Sealed HEPA Vacuum Cleaner 13"W, Wash Filter, Floors Carpets, 12A, 12Hose, 24Cord 15Lb
Hose setting, no suction through hose but not clogged. floor setting still works
Your filter may be stopped up and not allowing vacuum.
Your discharge may be blocked. In order to have vacuum you have to have a way to discharge the air.
Possibly your motor is weak
I found this info
Why is my vacuum losing suction?
A motor generates power which powers a vacuum which, in turn, creates suction to lift debris. The most common areas of suction loss are within the hose itself, the vacuum bag, clogged rollers, broken vacuum belt or a faulty gasket. All of these problems will lead directly to the vacuum cleaner losing suction.
2answers
Where does the belt go on the Electrolux el8807
EL8807 no belt, separate motor for brush, use reset button. Call customer service, see my other post with the number.
1helpful
Why would a Hoover Windtunnel have no suction?
It could be clogged at the head or throat, or you might have a hole in the hose. Unplug the hose; if you're getting suction where the hose plugs in then the problem is in the hose or the head. If you're not getting suction where the hose plugs in then the problem is in the body, probably the throat. If the problem is in the hose or head, detach the hose from the head and check for suction at the end of the hose. If there's not suction there, then you've got a clog or a hole. If there is suction there, then you've got a clog in then head.
May 20, 2014 • Vacuums
Riccar 8995 no suction
I think you mean it's an 8955, Riccar has not had a 8995 model. If there is no suction in the hose it has to have something clogging it. Open the little round opening on the back of the vacuum where the hose attaches to see if you have suction there.
Air not getting to hose
I'm not sure which model you have but this is good for Riccar upright vacuums. If the hose has good suction but is not picking up well check the suction tube that is down by the brush roll. The suction tube starts by the brush roll and goes to the back of the vacuum where you put the suction hose into. If it has a clog or restriction the vacuum will not pick up properly.
No suction in hose
There is most likely something stuck in the hose.
What do to if keeps spitting things out even if new bag is in?
It sounds like the roller brush is going, but the vacuum isn't working, i.e., no suction.
If you have a canister vacuum, disconnect wands from hose and place hand at end of hose. If there is suction, it's fine. If not, disconnect hose from vacuum, turn on vacuum, and hold hand to intake. If there's suction here, then the hose must be clogged; or holey hose can result in greatly reduced suction.
If it's an upright, the hose could be clogged. Or the fan broken, which would also result in no suction. It would help to know what model you have.
My Lindhaus Diamante 300 has great suction but clogs
Sounds like you have some form of an obstruction in the hose ( i once found a tooth pick sideways in mine) most models allow for the hose to be disconnected from the vaccum itself, also make sure theres not a setting for attachments also, some models need the suction redirected.
2helpful
Is there a switch to turn-off the tools so that
On the Hoover U6311-900 there is no switch that turns off the suction to the tool hose. That hose is attached to the head of the vacuum on the side via a spring loaded "door". Just twist the hose to remove it, the door will close and you will have full suction again.
2helpful
2answers
It has lost most of its suction power...what to do?
clean all the filters if this doesn't help then check for blockages at head, hose and entrance to collection chamber
May 30, 2009 • Vacuums
Top Electrolux Vacuums Experts
eVacuumStore.com
Mike Cairns
Mike Cairns
Kolbrun...
Are you an Electrolux Vacuum Expert? Answer questions, earn points and help others
