Definitely, I would start with making sure none of your neutral, white wires have vibrated loose from the terminal bars in the panel. Believe it or not, over time, the low frequency can actually vibrate the termination loose. Especially nowadays when people are getting paid by the piece and rush through the installation without tightening everything down fully
U have a loose connection somewhere, sometimes when an arc fault trips it will cause others to trip or you are having problems with more circuits than u think
SOURCE: Ground Fault circuit Breaker trips each time a load is applied
The most likely causes in their order of probability are: 1) water somewhere in the circuit causing the hot wire to ground; 2) a legitimate trip caused by a defect in a device plugged into the circuit; and 3) a defective GFCI breaker. In the first case, wait until it has been dry for about a week and see if it trips. In the second case, make sure there is nothing plugged into the circuit and try resetting. In the third case go ahead and put the regular breaker in, then put a GFCI outlet into the first box downstream from the breaker. If installed according to the directions, that outlet should protect all of the outlets downstream.
