SOURCE: Sharp 1870 just quit cooking and no turntable
The fact that the microwave and convection both do not heat indicated that the oven is in demo mode, check the user manual, otherwise it will possibly be a relay not triggering, may need a pcb replacement, check Demo mode 1st....Phil
SOURCE: Have a Sharp R930AK microwave.
You probably have a problem with the bottom door switch, or its mount may be loose or damaged.
We have
the service / repair manual for this model and have uploaded
it to our
site here for free download to help you.
It will
give you safety info, step by step help in disassembly, troubleshooting
tips, and part numbers.
You can order parts from
Encompass here
or you can call them toll-free at
866-779-5835.
If a switch is all you
need, we offer a universal type for only $5 postpaid which you can
order here.
Even though a door
switch clicks, it may still be bad inside.
Door switch
or mount trouble is usually caused by slamming the door or by opening
the
door while it's cooking without hitting the Stop pad first.
There are
plastic mounts inside the microwave which hold the door switches and
onto which the door latches lock when you close the door.
The screws on these
mounts may be loose. If they get too loose, the switches will not be
activated properly.
Sometimes it's
a broken tab on the switch holder, allowing the switch to rotate just
out of position. This tab
can be hard to see, since it is under the
bottom edge of the switch.
If the switch mount is
broken, it's usually more economical and
safer to add a dab or two of hot glue to the mount to secure the
switch. Let it cool for about 30 minutes before using.
If you still have questions, please reply back, otherwise...
We're
happy to help you with free advice and we'd appreciate your
thoughtful rating of our answer.
SOURCE: Sharp R-930 Microwave/convection turntable support burned
We have the service manual for this model and have uploaded it for you here.
You can order
parts from Encompass here or you can call them toll-free at 866-779-5835.
We're
happy to help you with free advice and we'd appreciate your thoughtful
SOURCE: My Sharp Microwave
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
