SOURCE: reddy pro155 runs for 3 to 5 seconds
Reply with the correct model number. "Pro 155" designates a series. We need to know whether you have a heater with a spark plug or a heater with an ignitor (glowbar).
SOURCE: my salamander reddy heater runs
To start with the air pump pressure must be set with a gauge. The air pump pressure is directly related to fuel delivery. There should be a label on the side of the heater designating the psi rating. Get it set right- don't guess.
Once the pressure is set and the heater is still acting up as you described, and I believe it will, because it sounds you are having an electronics problem. But if the unit starves for fuel the photocell will shut the unit down because it can't see a flame. If brought to my shop I wouls perform the following steps in this order:
Click here troubleshooting tips
Here are a couple of tips that I wrote that tell you how to troubleshoot a Torpedo or Reddy heater...
Reddy Heater - Troubleshooting Torpedo Heaters
Torpedo Heater Pump Pressure Adjustment
heatman101
