Question about Konica Minolta bizhub Office Equipment & Supplies
Use bizhub c220. Did use wrong toner. Cleaned the whole bizhub, drum, developer, bell etc. Put in new toner, chosen ad manual toner. Everything is fine but there is no toner in the developer units. I cant print.
SOURCE: adding developer to the new ricoh aficio mp 1500
Are you a tech? I suspect not. You need to remove the drum unit, disassemble, separate the drum from the development unit. Remove cover of developer unit, add developer, reassemble, and run SP2214 to calibrate.
This is NOT a procedure to be performed by an end user...no disrespect intended.
Posted on Apr 11, 2009
SOURCE: Afficio450 replace new developer unit wat procedure to be follow?
No, the 450 is just one of those machines that seem to have PCQ no matter what you do. Given light copies, I'd replace the drum for sure and make sure your ID sensor isn't covered with toner. Dust covered optics will also cause light copies on this model.
Posted on Jul 26, 2009
SOURCE: Toner life end.
-open front cover
-press 'Option' button
-then key *00 on the keypad
-This resets the device so it knows it has had a new cartridge.
I hope it helps
Posted on Apr 22, 2010
SOURCE: SHARP AR 5012 developer reset
i have a sharp sf 1025 , and i want to reset developer conter? can u help me pls
Posted on Jul 17, 2010
SOURCE: When I try to print, I get a consistent jam in the
Hello
Sometimes while clearing the jam (if there was one) you may leave a bit of paper left behind which obscures a sensor causing it to think there is paper still in the paper path, or sometimes even paper dust can do it. Try a bottle of compressed air and blow the path out very well. Get a bright light (good flashlight) and very thoroughly eyeball the paper path for any "foreign" objects.
THANK YOU FOR VISITING FIXYA
Posted on Feb 10, 2011
Oct 28, 2015 | Ricoh Office Equipment & Supplies
Jul 01, 2014 | Konica Minolta Bizhub c203 Copier
Apr 24, 2014 | Konica Minolta Developer 02xk Dv710 for...
Apr 21, 2014 | Konica Minolta Bizhub C454 Color Copier
Jan 16, 2014 | Konica Minolta bizhub 200 Printer
Jan 05, 2014 | Konica Minolta bizhub Office Equipment &...
Jan 05, 2014 | Konica Minolta bizhub C250 All-In-One...
Apr 11, 2013 | Konica Minolta Bizhub C550
Jan 20, 2011 | Minolta bizhub 250 Black and White Copier
Feb 28, 2008 | Sharp SF 2020 Copier
Dec 18, 2020 | Konica Minolta bizhub Office Equipment &...
185 people viewed this question
