It only happens during the spin cycle and when I looke at the back of the washer it almost looks like the basket is hitting the back of the washer and hence the hammering sound. The washer isonly 4 months ols.
Hi
a couple of suggestions, either a spring has broken at the base of the drum, there are 6-8 of these used to keep the drum central, remove the front panel to take a look.
or
The machine is not getting up to full spin speed causing it to wobble, try reducing the load or could be slipping belt.
Testimonial: "Thank you, we solved the problem but unplugging and replugging in the machine,"
SOURCE: Admiral Washer not spinning
broken or slipping drive belt, ( motor) to spin pulley , losse pulley, defitive drive clutch, spin brake fails to release, or transmission is frozzen
SOURCE: Admiral AAV8000AWW washer - clothes are wet after spin cycle...
may be a loose belt or a partial blockage somwhere.
SOURCE: Admiral washer won't agitate,drain, or spins
If your washer doesn't spin or pump water out but the motor is running, your washer probably has a frozen pump pulley. If so, you need to replace the pump. To check the pulley, remove the pump from the washer and try to rotate the pulley manually. If it doesn't turn freely--if it's frozen or stiff--replace it.
It doesn't spin
If your washer won't spin, check these:
It doesn't pump or spin
It pumps, but doesn't spin
It spins only with the lid closed
If it doesn't pump water out or spin, check to see if the motor is running, then proceed as follows:
If your washer pumps out the water but doesn't spin, check these:
For safety, washing machines are made so that they spin only with the lid closed. The lid switch prevents the spinning action when the lid is up
