Question about Rival Food Slicer
Need bolt & washer to hold blade 1101e-4 - Rival Food Slicer
Larry Allin
    New Friend:
  • 26 Answers
If you still need these parts, contact [email protected] As of 11/25/14 I have both available - the parts are recycled, not new, but perfectly serviceable.
Posted on Nov 25, 2014
Bolt and washer for rival meat slicer mod 1101e/3
I have these parts available as of 8/17/17, several recycled parts in stock. Contact [email protected] I also have blade washers and suction cup feet of recent manufacture.
Dec 23, 2016 | Rival Food Processors
How to change radiator fan blade on 1998 Toyota Tacoma
You must never have opened the hood &
even looked or ever worked on a vehicle
Appears all the motor options have 4 studs & 4 nuts
holding the fan clutch assy on & 4 bolts holding the
fan blade to the clutch
Nov 20, 2014 | 1998 Toyota Tacoma
I need a Rival Mfg. Co. Electric Food Slicer model 1101E-4 blade with gear can't find one
i have a rival 1030v electric food slicer in mint its nice ive never used it its just sitting around now.
Jun 03, 2012 | Food Processors
Need to know how to get the blade off the miter saw to replace the blade
First, make sure it's unplugged.
On many saws the guard mechanism partially covers the bolt that holds the blade in place. Loosen and move the part out of the way as recommended by the manufacturer. On this saw you loosen a screw and then slide the mechanism up and towards the rear.
Press the spindle lock to lock the blade in place. Turn the bolt clockwise - opposite the normal direction - to loosen and remove it. Remove the outer blade washer and the blade. Leave the inner blade washer in place. Wipe a drop of oil on the surfaces of the blade washers that touch the blade.
Put the blade on the saw so that the teeth point down. Putting the blade on with the teeth facing in the other direction can result in serious injury. Put the outer blade washer in place. Turn the bolt counterclockwise until it is snug, plus another 1/8 to 1/4 turn. Replace the cover and you're finished.
Oct 27, 2011 | Saws
My Craftsman 7&1/4 inch 12 amp Circular Saw(Model 315.108330) slips while cutting. The motor keeps spinning but the saw stops rotating. Can I Fix it?
Most circular 7-1/4 saws have a bolt and a compression washer that acts as a brake shoe that holds the blade secure but under dire circumstances will allow the blade to slip some rather than hold the motor shaft and allow burn out. The compression washer under your bolt has become worn and doesn't grip the blade securely. You can find a split washer that will fit under the blade and give you some more friction, or go to sears and order another compression washer for your saw.In the Sears Parts List found at: http://www.searspartsdirect.com/partsdirect/part-model/Craftsman-Parts/Saw-Parts/Model-32018780/0247/0744410/50035950/00001?blt=06&prst=&shdMod=
see part no. 44
Feb 23, 2011 | Craftsman Evolv 12 Amp 7-in Circular Saw -...
7 1/4 B&D saw - blade stalls but motor continues to run
There should be a special washer between the bolt (that holds the blade on) and the blade. If the arbor has a flat side on it, then the washer should have a matching hole so that the washer cannot turn independently of the arbor. Or, some saws use a spring washer which is cupped and becomes flattened against the blade as the bolt is tightened. If you have the first type of washer, perhaps the bolt is just not tight enough. If you have the second type of washer, perhaps the washer is backwards. If you have neither type of washer, you need one.
Jul 28, 2010 | Sears Craftsman 7-1/4 in. Circular Saw...
Cant remove blade on lawn mower
Follow directions. See if this works;
Blade Maintenance
�� Warning! Switch off, remove the isolator
key, battery and grassbox before adjusting
or cleaning.
�� Always wear gardening gloves when handling
or working near the sharp blades.
Turn the machine on its right side and inspect
the blade; if blunt or damaged, replace.
Use the following procedure to remove and replace
the blade:
Insert a screwdriver into hole 26 to lock the
drive. Hold the blade 30 using gardening gloves
(not provided) and use a spanner (not provided)
to remove the blade bolt 29, blade washer 28
and blade 30.
Fit the blade 30, blade washer 28 and the blade
bolt 29. Ensure that the blade is the correct way
up (so that this symbol can be seen located
as in figure I) and tighten the bolt 29 firmly.
Ensure the screwdriver is removed before attempting
to turn the machine on.
If this procedure does not work then try the following;
It is not uncommon for the blade bolt to become seized onto the shaft due to all the gunk and moisture on the underside of the deck. Try to soak the bolt several times over with penetrating oil ( WD 40, PB Blaster, etc). Spray the bolt head, the top of the blade where it contacts the shaft, etc. Do this several times and let the penetrating oil soak in. Hit the bolt head gently several times with a hammer to loosen up the corrosion. Then try to remove the bolt per directions.
Hope this helps, if so Please rate, Thanks, and Good Luck!
Aug 02, 2009 | Garden
Model 1101E Rival Food Slicer - grinds to a holt.
Im looking for the nut or bolt that holds the blade
Feb 01, 2009 | Food Processors
Rival Mfg. Co Food Slicer 1101E/7 - replacement screws
1101E part number for thumb nut 994-572, threaded shaft 995-254, blade 993-386, idler gear 348-077, washer 854-023, these are the Rival part numbers from the orginal owners manuel
Dec 09, 2008 | Food Processors
Rival Food Slicer Logo
304 people viewed this question
Top Rival Kitchen Appliances - Others Experts
Michael Thomas
Michael Thomas
Paul Carew
Are you a Rival Kitchen Appliances - Other Expert? Answer questions, earn points and help others
