Question about Texas Instruments TI-86 Calculator
Degrees to radians
Can't switch my calculator from degrees to radians... help?
Posted by zochitle on
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
Press "2ND" "MODE" to enter the mode screen. Press down-arrow twice to get to the angular mode. Press right-arrow or left-arrow to highlight the desired angular mode, then press "ENTER" to select it. Exit the mode screen by pressing "2ND" "QUIT"
Posted on Jan 17, 2010
How do I get to degree mode instead of radian
Hit the DRG key to the right of the pi key. It should cycle from radians to gradians to degrees. A "D" should appear at the top of your screen rather than the current "R".
Good luck.
Paul
Apr 01, 2014 | Sharp el-531x scientific calculator
My calculator is not computing sin^-1 or cos^-1 correctly, I put sin^-1(0.184) in and it came out with 10.60283... when I should be getting 1.39. HALP?
When the angle unit is in radians
sin^-1(0.184)=0.1850543940 radians
When angle unit is in degrees
sin^-1(0.185)=10.60283581
Your calculator is calculating the functions correctly)
In the following screen captures the sine of the values is calculated with the unit specified inside the formula (degree symbol and radian symbol are inserted to show you the unit). In the last calculation the value of the sine is practically 0.184
Remember that when angle is in radians, for very small angles (less than 10 degrees), sin(x) and tan (x) are about equal to the value of the angle in radians
Mar 25, 2014 | Casio FX-115ES Scientific Calculator
How do I switch between degrees and radians?
Press SHIFT MODE and then 3 for degrees or 4 for radians.
Nov 29, 2012 | Casio fx-115ES Plus Scientific Calculator
I have to take the secant of -1.2. I'm supposed to get a degree. I can't figure out the order to push buttons. PLEASE help!
TWO THINGS YOU NEED TO KNOW, Eli.1. Secant will NEVER return a degree measure (or even a radian measure) no matter what computer or calculator you use. The reason is because secant returns the ratio of sides (hypotenuse over adjacent), which has a range of and find its reciprocal (ie, flip the number upside down: the reciprocal of 5 is one-fifth). That's all.B. TI-84 only uses the three basic trig functions. Secant is the reciprocal of cosine. Therefore, in order to find the secant of -1.2 radians you need to be in Radian mode (see #2 above). From there, you just find the cosine of -1.2 and take that values reciprocal (ie, flip the number upside down: the reciprocal of 10 is point one) . That's all. Math lesson: 1 Radian = 180 Degrees. Therefore, 1.2 Radians is roughly one-third of pi, therefore it is roughly one-third of 180 degrees; therefore -1.2 radians would be nearly -60 degrees (a very friendly angle measure). I hope that helps If not, you should call Texas Instruments because they've got friendly people who are happy to assist anyone. Questions like this are right up their ally, advanced questions like the syntax of the poisson cumulative distribution function are not. So, you're fine. For in depth math help holler at www.THEMATHCHEETAH.comIn Short: Secant returns ratios and NOT degrees or radians. Secant is the reciprocal to cosine. Arcsecant WILL return degrees/radians. Your calculator can be set to either mode.TEXAS INSTRUMENTS >>>>> all calculators ever made.
Mar 08, 2011 | Texas Instruments TI-84 Plus Calculator
How to switch between radian mode and degree mode
Press SHIFT MODE then 3 for degree or 4 for radian.
Dec 04, 2010 | Casio FX-115ES Scientific Calculator
How do you switch between degree and radian mode on the fx-115 ES Casio calulator? Thanx
Press SHIFT MODE to access (SETUP)
Press 3:deg for degree OR
press 4:Rad for radian.
Apr 02, 2010 | Casio FX-115ES Scientific Calculator
Converting degrees and minutes and seconds to radians
With the TI8x/TI8xPlus you can enter an angle in degrees (Angle mode must be set to degrees) and convert it into DMS representation the following way. Exemple
18.675 [2nd][ANGLE][4] [ENTER] gives 18deg 40' 30''
If Angle [MODE] is set to degrees you can enter a number in radians and convert it into degrees. Exemple How many degrees are ther in 1rad ?
[1][2nd][ANGLE][3] display 1 with a small r as superscrit. Pressing [ENTER] yields 57.29577951
To convert 1rad into DMS, takes a little effort but can be done: you have
to convert radians to degrees and the result [ANS] into DMS.
You cannot use an angle written in DMS in any calculation.
But if you want to convert an angle from degrees to radians enter your number and divide by 57.29577951
Hope it helps
Sep 02, 2009 | Texas Instruments TI-84 Plus Calculator
On my TI 83 plus my sine cosine and tangent buttons are giving incorrect answers.
Alot of people seem to be having this problem. Angles can be measured in two units, degrees and radians. Your calculator is currently doing everything in terms of radians. I have an 84 but I'm sure the 83 is similar, go under MODE and look for Degrees and Radians and make sure you choose degrees. if you have to convert, 360[degrees] = 2* pi [radians]
(easy to remember, 360deg in a circle, 2pi radians in a circle)
Good luck
Aug 11, 2009 | Texas Instruments TI-83 Plus Calculator
Using Tan,sin, cosin
Alot of people seem to be having this problem. Angles can be measured in two units, degrees and radians. Your calculator is currently doing everything in terms of radians. I have an 84 but I'm sure the 83 is similar, go under MODE and look for Degrees and Radians and make sure you choose degrees. if you have to convert 360[degrees] = 2* pi [radians]
Good luck
Radians and degrees flipped
reset ur calculator. press 2nd 6 F1 3 Enter. Note that all your data will be gone
Jun 07, 2008 | Texas Instruments TI-89 Calculator
Texas Instruments TI-86 Calculator Logo
124 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
Ekse
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
