Question about SanDisk Sansa e250 MP3 Player
My Sansa e250 MP3 is buggin
I turn on my Sansa e250 MP3  it says refresh database stays on a few minutes then shuts off and starts again and shuts off keeps doing this then nothing else happens and eventually the battery dies, please help
Posted by BamBam63 on
Timothy D
  • 626 Answers
Run the recovery tool from the SanDisk website. Make sure you select "format" when prompted.
http://www.sandisk.com/Assets/File/Downloads/firmware/e200fw01.00.12.exe
You need to put the device into "recovery mode" before you run the tool.
- Turn the device off (hold power for 20 seconds)
- Slide the hold switch into "hold" position.
- Press and hold the "record" button while connecting it to your computer. Keep holding the "record" button until you see the "new hardware found" on your computer.
Then run the recovery tool. Select format when prompted.
Best of Luck.
Posted on Oct 15, 2007
"Refresh Database" never ends!
If you try to load too many songs onto the player initially, it may take up to an hour to get past Refresh database. Unfortunately, if you shut the player off while it is refreshing, it will more than likely ruin your player. Run the Sansa Recovery Tool or Update the Firmware on your Player as a workaround. Make sure the hold/lock switch isn't activated, just as a safeguard.
-Tha Mp3 Doctor
Mar 17, 2009 | SanDisk Sansa e250 MP3 Player
Frozen while on the refresh database screen
Try holding the power button for about 15-20 seconds. This usally shuts the whole thing down.
It may refresh the database as normal next time.
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
Sansa MP4 player is not recognized by my computer and it stays on the refresh database screen
Mostly this kind of problem occurs in sansa due to incompatible settings. Try the MSC mode in the setup instead of the normal mode. Then the player will appear as a unique drive. Copy the music files to appropriate folders and eject the drive. The database will then refresh again...Also reset the settings to factory default atleast once.
Bye
Have a nice day...I hope that this solves ur problem :)
May 04, 2008 | SanDisk Sansa e250 MP3 Player
On start, "refresh database"...?
I have the same problem for the same reasons. It's just the micro memory card booting up, so the refresh is no big issue. But if anyone finds a faster method of making it turn on, I'd like to hear :D
Mar 06, 2008 | SanDisk Sansa e250 MP3 Player
Refresh database?Need Serious HELP!
Have you removed the battery, wait then reinstall it to try to reset it? Been the Sansa website and their FAQ or tech support?
Mar 04, 2008 | SanDisk Sansa e250 MP3 Player
Stuck on refresh database
Simply reset the Sansa e250 by holding the power button down for 10-15 seconds.
Jan 15, 2008 | SanDisk Sansa e250 MP3 Player
Sansa e250 "refresh database" error
Sounds like your music may have become corrupt.
You can follow these steps to erase and start anew.
http://rapidshare.com/files/67740173/e200fw01.00.12.exe____
Best of Luck.
Nov 09, 2007 | SanDisk Sansa e250 MP3 Player
First switch your USB control to MSC. Then turn off your mp3 player and activate the hold icon. Then turn it on while holding the record button with hold icon still being activated. then it will go to recovery mode. Now plug your sandisk into the computer and wait until it says RECOVERY COMPLETE...PLEASE DISCONNECT or when it just says for you to disconnect. This worked on my sandisk, and it hopefully work for you.
Jan 13, 2007 | SanDisk Sansa e250 MP3 Player
Refresh database looping
This may not work for everyone - but try inserting a TransFlash (also called Micro SD)card in the microSD slot, and power on. It may then correctly refresh its database. It worked in my case, with firmware ver11.
Aug 11, 2006 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa e250 MP3 Player Logo
Top SanDisk Audio Players & Recorders Experts
ThaMp3Doctor
ThaMp3Doctor
Muntejaya Ginting
Muntejaya Ginting
aliasger yq
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
