The Microwave come on the plate turns but food is not heated
SOURCE: sanyo microwave EM-X515G
I'm thinking that the circuit board has a problem. I doubt it will work but disconnect all the connectors on the board...with the power off and reconnect. It may clean off some goo. If not, use your method as long as it will work and then consider a new board.
SOURCE: Sanyo microwave mod # EM-2100GS
unscrew the unit replace fuse near the transformer. this fuse is for heating....
Could be the Magnatron, Diode, HV Cap or Transfomer, some also have a high voltage fuse that blow. Unless you really are confident playing with Very High Voltages, and have a meter capable of 5000v, I dont recommend you repair yourself as a microwave will happily electrocute you. Also if the discharge resistor has burnt out on the cap (assuming it was fitted on your model) the capacitor can store enough power to kill you even when the unit is unplugged so you must discharge the cap before playing with anything else to be safe.
SOURCE: Microwave not heating food
I have exactly the same problem - strange and annoying! Did you manage to fix it?
Cheers,
Ben
SOURCE: Sanyo microwave EM-3310
http://www.givemefile.net/smanuals/_microwave_ovens/sanyo/file/6419.html
http://www.repairfaq.org/sam/micfaq.htm
OK above is a service manual, this should get you into the "ball park" I have given you also a DIY repair of microwaves.
Usually, the magnetron, or High Power Diode, is what fails. Anyway perform the troubleshooting steps, and you should be able to sort it out.
BE CAREFUL. Microwaves are LETHAL.
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic Microwave Oven Troubleshooting Tips
heatman101
