Question about Texas Instruments TI-86 Calculator
0.35% as a decimal - Texas Instruments TI-86 Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Texas Instru... Master
  • 102,366 Answers
0.0035
Posted on Jun 11, 2014
Simple pro rata formula for time and money. ie. 1hour = $35 so how long for $23? cant get my head around 1 hour being 60 mins
I suggest you adopt the decimal clock. 0.1 hour (6 minutes) will be $3.50 or 0.05 hour (3 minutes) will be $1.75 and once you have a policy of using those decimal units, time and therefore the cash amounts will be rounded up to the nearest 0.05 or 0.1 hour.
To answer your question use a calculator and divide the required amount by $35 to obtain a decimal fraction of an hour, in this case $23 will buy 0.657 hour which for practical purposes is an unwieldy figure and for most purposes be rounded up to 0.7 hour (42 minutes).
If greater accuracy is required 0.657 x 60 (minutes) = 39.06.
Lots of workshop environments use the decimal clock and vehicle standard repair times and the resulting charges are decimal, the majority to 0.1 but some to 0.05.
I hope this is helpful...
Jan 21, 2017 | Pro Computers & Internet
How to remove BIN from, HP 35 Scientific Calculator
Press right-shift [BASE] 1 to switch to the decimal mode.
Nov 19, 2013 | HP 35s Scientific Calculator
How to use % percentage?
You cannot type a percentage sign, you must use the decimal form. 50%=.50, 35%=.35, etc.... (Divide you percentage by 100)
Sep 13, 2011 | Texas Instruments TI-30XA Calculator
Not knowing how to get the percentage on a figure from a calculator
Sep 12, 2011 | Office Equipment & Supplies
2.45.35 hours - 0.23. 12 hours = ?. a short quick method please
Seconds: Subtract 12 from 35 to get 23.
Minutes: Subtract 23 from 45 to get 22
Hours: Subtract 0 from 2 to get 2.
Put the three together to get 2.22.23
This one was easy because there was no need for carry. If you do have to carry, just make sure you carry 60. Otherwise, it's exactly the same as when you learned subtraction in second grade.
Some calculators have conversions between decimal degrees/hours and degrees/hours:minutes:seconds. If you have such a calculator, you can convert both numbers to decimal, subtract, and convert back. Since you didn't specify what calculator you have, I can't tell whether this is an option for you.
Jun 18, 2011 | Office Equipment & Supplies
I need to learn how to turn off exponents - I am dividing 35 by 360000 I want the regular decimal number, not the exponent factors. Help! Thanks! New to my TI-81. Jessi
You just select [MODE] use your left arrow if needed to select [Norm]. You might want to look at the other mode settings to select the ones that apply to the type of math your doing. But, [Norm] will put you in straight decimal form. To escape out of the Mode screen after you select [Norm], just [2nd][Clear] to quit should take you to Home screen.
Dec 28, 2010 | Texas Instruments TI-81 Calculator
How do i get the answer of a simple arithmetic in decimals?
There is a button there that says "S<=>D". Compute it first and when the result is in fraction, press this and it will be in decimals. This button is just above the DEL button.
May 12, 2009 | Casio FX-115ES Scientific Calculator
Polar/rectangular
For a TI-86
Converting rectangular to polar
Press "2ND" and then "MORE" for the MODE screen
Highlight PolarC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5+j6
Enter "(5,6)" in the calculator and press "ENTER"
Should get (7.81024967591*angle*50.1944289077)
Converting polar to rectangular
Highlight RectC and press "ENTER"
Quit that screen.
Now ready to go.
A example of converting 5*angle*35
Enter "(5*angle*35)
Should get (4.09576022145,2.86788218176)
Note
*angle* is the symbol when you press "2ND" then ","
Note 2
To round the an decimal places press "2ND" then "MORE" for the MODE screen and on the line that says float, choose a number on that line for the number of decimal places you would like to have.
More can be found at
http://docs.google.com/gview?a=v&q=cache:nAC57BtC6IIJ:myweb.wit.edu/khabaria/ELEC195_files/ti86cplx.pdf+ti-86+convert+to+polar&hl=en&gl=us
Dec 02, 2008 | Texas Instruments TI-86 Calculator
I have a problem
This is a common starter challenge in college and high school programming classes. While i'm not willing to code it for you, I can show you the methods you'll need to understand in order to approach the problem. The easiest way of doing this is by using a brute force method. Just keep testing the number to see if the remainder after dividing it with a number lower than it is zero. If so, it's a factor.
For example, If the number is 35 then pick a number just one lower than it that's not the number 1. Now divide the two numbers. 35/34 = a number with many decimal places after it, which means its not one of the factors of the number. However, eventually, you'll approach the number 7, and 35/7 = 5. This number has no decimal, meaning it IS a factor of 35, and also the largest non-zero factor of 35. Your algorithm can now stop, since it found the largest non-zero number.
Here's some pseudo-code:
int largestfactor(int number) {
int temp = number;
for(temp - 1; temp>=1; temp--) {
if (number % temp == 0) return temp
return temp
Something like that, with some bug tweaks will do it. The "%" sign is called a modulus. It's a standard c++ operator. Good luck, and remember to vote Fixya if you liked it.
The wikipedia article that helps you with better and more effecient algorithms can be found here.
Steven
Sep 15, 2008 | Computers & Internet
Texas Instruments TI-86 Calculator Logo
23 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Paul Bade
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
