Black screen
SOURCE: Alpine IXA-W404 how do i can't get video to play.
You need to connect the yellow/black wire to the brake switch and the yellow/blue wire to the ground wire on the hand brake. After that you have to go through the task of holding down the foot brake, pull the hand brake, release the hand brake, pull the hand brand then release the foot brake.
after all that then you can watch your video. You will want to connect those wires so you can setup your system.
SOURCE: Bypassing the ebrake-grounding doesn't work on Alpine-iXA-W404
Found the solution
Either get a pair of toggle switches to simulate the Foot Brake and Parking Brake OR get a product (from PAC) that simulates it for you.
SOURCE: i had my alpine ixa-w404
Your Yellow (constant battery) wire is not properly hooked up. The yellow wire is what keeps power to your unit while the car is off so that it keeps all the memory. I would start by checking to see if that wire is connected right and if so, start to trace it back from there. Hope this helps and good luck!
SOURCE: Setting time on Alpine iXA-w404
Are you holding the setup button down for at least 2 seconds? Then using the >> to switch items for setup? If you don't have the manual, download it here and flip to page 20:
http://support.alpine-usa.com/products/documents/OM%20iXA-W404_EN.pdf
