Question about Samsung UN26EH4000 4000 Series 26-inch LED LCD HDTV
No HDMI input Samsung 26" - Samsung UN26EH4000 4000 Series 26-inch LED LCD HDTV
Posted by Cyrus Overbey on
John Ray
  • 790 Answers
Try the link for trouble shooting
Posted on Apr 24, 2014
I can't get audio to work on my Samsung UN40HU6950F UHD TV HDMI 1 input using the Time Warner Cable Cisco 4742HDC cable box.
if all 4 inputs work with another input source(i.e. your Motorola box) it indicates the issue is with the TWC input source. Also check your HDMI cable to be sure it is in good condition & properly plugged in on both ends.
Jan 12, 2015 | Samsung UN40HU6950 40 Inch Ultra Smart
My HDMI 1 is dull but when i put it on HDMI 2 its clear... and when i go to menu on HDMI 1 picture only can set backlight, contrast and brightness... I cant go to sharpness, color, tint and advanced...
Hi chaz,
I see that your HDMI 1 is having problems when used and on the HDMI 2 everything is ok and clear.
I believe this cannot be fixed since this is going to be a hardware issue, there are no settigns for the HDMI to change any settign rgarding video, the only setting you can get is for the whole LCD TV itself and regardless of what input you use the settings will be the same.
You may need to have that HDMI port check from the manufacturer if you still have warranty on your LCD tv.
I hope this helps.
Have a nice day,
mvincentc
Apr 13, 2011 | Samsung LN26B360 26 in. LCD TV
HDMI inputs do not read anything is plugged into them
Make sure the unit you are using is turned on. Also make sure you are the correct video. What component are you trying to use?
Mar 01, 2011 | Samsung UN26C4000 26 in TV
"No Signal" Message when using HDMI Inputs on 26" Proscan LCD TV
You MUST get HDMI Driver for your Video Card, it is NOT standard. You need to go to PC makers web site and download latest Video Divers for your PC, then you must set up Multiple Desktops, To do that you must first connect the TV, but leave OFF, connect up to PC, reboot, setup Video Card, turn ON TV, TV will have already been detected, On PC, Share the desktop, or Clone, whatever you wish, now reboot after saving settings. Now you set the TV for HDMI already and it should show you a desktop when chosen. You must select and setup TV, FIRST, then connect the PC. From then on, Turn the TV ON, then turn the PC ON, that way it will Always detect the HDMI port.
Apr 23, 2010 | Proscan 26LB30QD 26 in. LCD HDTV
Samsung 40" lcd - Connecting to PC saying 'MODE NOT SUPPORTED'
First of all, check that the TV is set on PC input when you use PC video input at the back.
Then you may also need to go to video and display properties>>settings, from control panel (personalize on Vista).
There lower down resolution and ensure that frequency is set the same as tv.
Jan 02, 2009 | Samsung LN-S2651D 26 in. LCD Television
HDMI Problem
check your owners manual tv. my tv has 3 hdmi input.your tv manual will tell you which one to use. make sure you select the correct resolution. 1080p/720/480 etc. oh...make sure you have hdmi cables too
Nov 08, 2008 | Samsung LN-T2653H 26 in. LCD HDTV
KDL-32XBR6
Try resetting the TV by holding down the "up" button on the remote (with the TV powered on) and then, while you hold down the up button on the remote, hit the power button on the TV. This should do a "factory reset" which will wipe all settings in the TV. There is no reason why the TV should not "remember the last input it was on when it was ;last turned off. Also be sure that the TV is not plugged into a switched AC outlet, like the outlet on the back of the cable bix. The TV should be plugged into an output that receives power at all times.
Oct 19, 2008 | Sony BRAVIA KDL-32S2000 32 in. LCD HDTV
Sansui 26 HDLCD DVD Audio DVI/HDMI
Does Sansui HDLCD 19WB have a HDMI outlet
Oct 18, 2008 | Sansui HDLCD-2600 26 in. LCD Television
Samsung LE26R51BD HDMI PROBLEM
Sounds to me like you need to change your input feed oin the settings menu of you TV to HDMI. If it doesn't work then you can either return the DVD player because using an HD DVD with a non HD capable TV is pointless, or you can upgrade to an HD TV.
Mar 15, 2008 | Samsung LN-R268W 26 in. HD-Ready LCD...
Not supported mode lcd tv samsung lnt4061f
with the PC input or analog SVGA the only 16:9 resolution it supports is 1920x1080, which can be difficult for some older systems to handle. However, on HDMI it should support all the standard HD resolutions.
Dec 29, 2007 | Samsung LN-S2651D 26 in. LCD Television
Samsung UN26EH4000 4000 Series 26-inch LED LCD HDTV Logo
Top Samsung Computers & Internet Experts
Muntejaya Ginting
Muntejaya Ginting
ThaMp3Doctor
ThaMp3Doctor
Tareq Bin Mostaq...
Tareq Bin Mostaq...
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
