Question about Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan
My fan and lights wont turn on
I had installed my fan and it worked perfect.  A couple of days latter it stopped working.  Please help.  I un-did the cap by the down-rod and can not figure out what is wrong.  Please advise.
Posted by babyjarin on
  • Anonymous Dec 17, 2007
    should i check the receiver
  • Anonymous Dec 13, 2008
    Not circuit breaker !
Anonymous
My fan and lights stop working.Please help ! Please Advise !
Posted on Dec 13, 2008
Anonymous
Make sure you haven't tripped a circuit breaker.
Posted on Mar 04, 2008
My pacr10 blows air but compressor wont kick on
sounds like a blockage in the refrigerant circuit, the compressor is shutting down, protecting itself. possibly the compressor is overheating, possibly it's overcharged.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Oct 13, 2017 | Windchaser PACR10 Portable Air Conditioner
Since friend un blocked nail,fan wont stop running and wont fire.
somehow the safety switches have become jammed. I would suggest taking the front cylinder off again and checking the o ring at the top where the fan is for being pinched and then without the front cylinder cycle the unit. BE CAREFUL with the fan, insert the battery and push on the trigger switch, fan should come on and go off after a couple seconds. Then towards the top you will see a roller type switch, depress (watch for fan blades) and again fan should come on and go off after a couple seconds. For the final test depress and HOLD the roller switch and then engage the trigger and you should see fire, try this a couple times, if all works then check the lower probe for free movement (depress probe a couple times and watch the combustion chamber for movement to the top) relube the o ring and be careful not to pinch when reassembling. It sounds compllicated but it is really quite simple. Let me know if you need more help
Apr 25, 2011 | RTO PasLode 900420 Impulse Framing Nailer
My Acer Aspire 9300 laptop wont turn on......light indicators are on (motherboard light blinks once, light bulb and battery lights on) but no power to fans so no start up. have had this happen before but...
Very possible that something has short circuited on the motherboard. I would also try re-seating the memory located on the bottom of the laptop(which could be loose explaining the intermittent nature of the issue). On an IBM I once fixed that had the same issue I took out the CMOS battery and battery for one week and then re-installed and that fixed the issue. But good luck to you!
Sep 23, 2009 | Acer Aspire 5315 Notebook
My psp wont turn on ,but the green light stays on for a couple of
firmware could have crashed. welcome to a 150$ paper weight. sorry.
computers can run into the same issue if a bios update fails or corrupts.
sony might be willing to fix it.. maby.. or game stop might buy it off of you.
Aug 06, 2009 | Video Game Consoles & Games
Ceiling fan and lights with remote control
I got a new reciver installed in ceiling fixture,works fine:Boytin
Mar 15, 2008 | Hunter 52" Ceiling Fan With Light And...
Remote control fan
I had the same problem and I thnk Hunter Fan knows about it....I just called Hunter Tecnical Support at 901-745-9222 and they sent me a new White circular receiver which goes inside of the canopy and it worked fine after installing the receiver....
Mar 14, 2008 | Hunter 21871 56'' Ergonomic Brushed Nickel...
Hampton Bay 48670 Flemish Pewter Finish Ceiling Fan Logo
175 people viewed this question
Top Hampton Bay Dryers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
LightingWorldBay
LightingWorldBay
Are you a Hampton Bay Dryer Expert? Answer questions, earn points and help others
