Question about Black & Decker Compact Power Screwdriver
Drill wont tighten to drill holes - what am i doing incorrectly
Posted by cubbyz on
chuck ringwood
    New Friend:
  • 11 Answers
4 1 thing is the drill smaller than the drill PORT/HOLE in ur drill.? or the drill PORT/HOLE to small for the drill bit? lok/see/listen?! wat kinda drill? more details for usin out here, an maybes we kin hep u out. or hav u fised it by usef??
Posted on Jun 15, 2012
Anonymous
    Champion:
  • 313 Answers
Chuck problem replace it,
Posted on May 29, 2008
Changing speeds on Powermatic Drill Press
Katie,
Refer to the picture below. Loosen the locknuts (the one on the right side of the drill is shown, there is another on the left side). Use the lever to move the motor toward you, thereby loosening the drive belt(s). Open the top cover to expose the belt(s) and sheaves (most people incorrectly call them pulleys). You might have one belt and two sheaves, or you have two belts and three sheaves. The drill will go fastest when the belt is on the biggest motor sheave and the smallest sheave on the drill spindle. Of course the opposite sizes apply for the slowest speeds. Make sure the belt uses a pair of sheaves that are at the same height as each other (the belt has to stay in one plane). Now tighten the belt(s) by pushing the lever pretty hard away from you, and while holding it with your right hand tighten the left side locknut with your left hand. Now tighten the right locknut. Close the cover. ----- OK, so now you know how to CHANGE speeds, what about drilling glass? This can be tricky. You must use a pretty slow speed (maybe the slowest, depending on the size of hole you are drilling. And you must keep the spot you are drilling flooded with water to keep the glass cool. And you must apply pretty gentle pressure. And the use of a drill bit intended for drilling glass helps a lot. And don't try the first hole in something expensive! Practice on something disposable first. Take your time. AND WEAR SAFETY GLASSES!
Jun 15, 2012 | Powermatic Drills
The chuck on my 18volt drill will not hold a drill bit long enough to drill one hole. i have 3 of these drills they all do the same thing
Hi. I'm guessing it is a keyless chuck. I always have to use two hands to tighten mine. Is drill running forward and not in reverse?
Sep 10, 2011 | Garden
I have the drill, I have the bits...there is something missing to connect both. What does it look like?
Although you posted your question under Chainsaws instead of another tool forum, look at the end of the drill. Is there a hole surrounded by a cone shaped metal end? This is the chock, if you spin/turn it counterclockwise, the opening should widen to accommodate the drill bits, then spin/turn it clockwise to tighten/clamp down on the drill bit. Some drills accomplish this with an l-shaped key that has a small cone-shaped gear on the end that fits into holes on the chock. Some drills have a chockless drill, and you simply hold the end of the drill and squeeze the trigger to use power to tighten/loosen the bit.
Aug 31, 2011 | Garden
How do I use a Vermont American #17192 Drill Press Stand? Anyone have an instruction sheet for this? I acquired one from a sale but am unable to figure out how to mount our drill onto it. Thanks.
Here you will see how the drill is mounted in the device. Position (b) around the handle and tighten it up untill drill seats firmly in place. Take a speed square, or normal square and eyeball or measure the drill to see if its straight. Use the alignment adjustment (A) to fine tune the drill to get the drill bit straight and square. Tighten up all the nuts holding drill in device and recheck the drill bit for straightness.. Put your work under the drill, press the trigger and lock into place to get the drill to constantly run without finger on trigger, pull down the press lever to drill your hole... Hope this helps!
Nov 02, 2010 | Drills
Drill bit keeps coming loose
When the drill bit on a hammer drill keeps loosening up one of two things is happening. 1. The chuck is worn out and needs to be replaced. 2. The chuck is not tight enough before you start drilling. If you have the style of chuck that requires a key do not be bashful about using maximum force to tighten the chuck and move the chuck key from hole to hole and tighten it in each position. Joe
May 08, 2010 | Drills
How to tighten drill bit on makita 6343d
your must have a keyless chuck. hold the black center part of the chuck and run the drill forward or backward to open or close the chuck.
Jan 26, 2010 | Drills
How to change the drill bit
there is a rippled edge close to the very tip of the drill and there is a key supplied with the drill with the corresponding ripples place key into the hole near tip of drill so ripples meet each other and turn key in an anticlockwise direction to loosen put in new drill bit re tighten in clockwise direction hope this helps if not please ask for more info glenn
Nov 23, 2008 | Black & Decker 3/8" Variable Speed...
Press stops under even slight pressure on drill
adjust tension on pully or the belt may be worn or streched replace belt.
Nov 15, 2008 | Drills
Inserting new drill bit
Assuming that it is this drill:
http://www.toolpartsdirect.com/cgi-bin/schematic.cgi/blackdecker/7144-04_TYPE_4
You will need a chuck key - hopefully you have that with the drill. It's a little t-shaped bar with a cog on one end. You put it into the holes in the chuck (the part at the end which grps the bit) and turn anti-clockwise to open the jaws. Place a bit in the centre and then turn it clockwise to tighten. Tighten the bit using each of the three holes in the chuck and make sure you remove the chuck key before you use the drill - keep it safe!
Sep 23, 2008 | Drills
Black & Decker Compact Power Screwdriver Logo
450 people viewed this question
Top Black & Decker Hand Tools Experts
Marvin
Marvin
efs_perpends
efs_perpends
Bill Boyd
Are you a Black & Decker Hand Tool Expert? Answer questions, earn points and help others
