Question about Stanley Utility Knife
How do you load a Stanlet 10-480 razor knife?
Posted by Dave Hanley on
How do I remove a bathrub/shower pullout faucet handle?
What is the brand of faucet? Faucets are designed so that you do not see the set screw. On the underside of the handle, you may see or feel a small, rubber plug button. I typically use the tip of my razor knife to gently remove the plug button. Once removed, you should gain access to a set screw.
If you have an older style, you may have a plastic handle. If this is the case, on the face of the handle, you should notice a line of separation between the handle and cover plate. Again, I typically use a razor knife to gently pry the cover plate from the handle. On the backside of the cover plate, you will typically find a Phillips screw that holds the handle in place.
Oct 17, 2014 | Home
How do I get my bar ends off on a 96 Honda CBR 900
cut them with a utility knife or a single edge razor blade utility knife is safer
Sep 23, 2014 | Motorcycles
The cutting disc on my makita 5806b spins anti clockwise causing damage if i cut laminate from the top and i need it to spin clockwise
You could turn the laminate over.
The proper tools would be either a router with an edge bit ( what I and most cabinet makers use ) or a low tech utility knife (carpet knife ) yep just a razor knife - really it works.
Don
Jun 12, 2014 | Makita 10" Miter Saw LS1030N
I have a 2006 Mazda Tribute and noticed that water was leaking in the driver's side. I just happened to notice something flapping against the windshield and it was the rubber that seals it. I got out and...
A cheaper solution might be to obtain black sealant and fill all missing pieces and gaps. Available from most auto part stores. apply sealant liberally and trim excess with razor knife/exacto knife, or flat razor scraper. Petroleum-based sealants may be cleaned away from glass or paint with kerosene or gasoline.
Sep 22, 2013 | 2002 Mazda Tribute
What is the proper way to cut drywall with a razor knife?
use a level or straight piece of drywall, and place it along the drywall you want to cut, cut with the knife along the straight edge (you dont need to cut through the entire width of the drywall). Then fold the drywall on the cut, and while folded cut the other side of the drywall paper. you should have a clean, straight cut
Jan 16, 2013 | Drywall
What is wet shaving?
Wet shaving at its simplest, is just that - shaving with water, a razor blade, and some sort of lubricant (lather, soap, etc.) on your face. Men have shaved this way for centuries, starting early on with a sharp knife or stone, progressing to the straight razor, safety (double-edge) razors, and eventually cartridge razors from companies like Gillette, etc.
Nov 23, 2010 | Health & Beauty
How do I open the case to change the battery?
There are 2 removable plastic plates on either side of the power entry connector> Pry these off with a knife and remove the 2 screws. Next slide the razor out of it's case. The batteries are soldered in.
Gary
Apr 22, 2009 | Braun 4501 Electric Shaver
Can't open the wrist watch case
Use a Testor's razor knife with eye protection. Use as much of the blade edge as possible. The Testor's blades are fairly strong and thin and I have used them on many Skagens before. I have had some Swiss cases with no gap or tab and the tightest tolerances and the Testor's hobby knife blades were the only hope and solution. Please use care and eye protection for any repairs or service of this nature. Things break and fly off with great force. Including the blade of a knife or razor knife.
Dec 03, 2008 | Skagen Watches
Stanley  Utility Knife  Logo
430 people viewed this question
Top Stanley Cutter Tools Experts
efs_perpends
efs_perpends
JOHN LAPIER
Joe Garcia
Joe Garcia
Are you a Stanley Cutter Tool Expert? Answer questions, earn points and help others
