Question about HP LaserJet 5200 Printer
Unable to pick up papaer on tray 2 error 13.00
Posted by dilipkumar... on
Pete Fotheringham
    Novelist:
  • HP Expert
  • 175 Answers
Common faults for poor feeding on lj5200
1, feed rollers are worn - replace
2, sep pad is worn ( cant seperate pages correctly)- replace
3, paper empty tray sensor actuator arm snapped - unable to raise cassettetray- replace arm
4. paper feed roller fail to turn- feed unit clutch assy faulty- replace feed asseembly
5.paper tray pass guide out of position (blocking feed path) - pin that holds in place has snapped- replace feed assembly
Posted on Jan 30, 2014
How do I fix the "phantom paper jam on P3015?
Do you have an error code? Usually if you get a jam error and there is no paper in the printer it is because the printer was unable to pick the paper out of the tray. Try printing from the drop down manual tray to confirm that the printer itself works. If it does, then clean the roller in tray 2 with a damp cloth and make sure you dry it completely.
Sep 29, 2014 | HP P3015 Laser Printer
Co960 2510
Sir/Mam
You mite want to check the manual bypass tray located on the rightside of the copier below the side door, looks like a step!!!! The rollers maybe dirty or the something stuck in it. if printing to the copier and asking for the bypass tray recommended that you send the print job over to the machine first then place the paper in the tray when the machine indicate to replenish paper in the bypass tray. It is important that when using 81/2 x 11 papaer that you look at the little icon on the operator screen to see weather to place the paper on the bypass tray in potrait or landscape paper will jam if not seated properly.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Aug 06, 2014 | Minolta DiALTA DI2510F All-In-One Laser...
Dell 3115 manual feed doesn't work
If this printer is a few years old on the load paper tray there is 2 grey rubber rings they get a flat spot on them. replace and no paper problem till the next time they wear out
May 25, 2012 | Dell 3100cn Laser Printer
Printer i making a weird clicking sound. It won't print. It has error light On. Status: load tray 1 / Plain letter Toner level is 80%
check if there is a paper at tray 1. if so, may be the printer is unable to pick up paper due pick-up roller problem. try to remove the tray and look in the middle, there should be a rubber like roller. if its too glossy it cant pick the paper.
Sep 18, 2011 | Dell 1720dn Laser Printer
The printer is saying that paper was misfed and it says that procedure for clearing misfed paper is shown inside the front door : C and A
First you have to open all the doors see their are two papers are get jamed in side, one paper at C section that meens in fuser module and another one in lower papaer tray section you can find the nob of C when you open the front door please rotate that the C jamed papaer comes out and other one open lower right door op tray-2 and tray-3&4, you can see the Ajamed paper remove that and close all the doors if problem exists call expert-thankyou
Dec 15, 2010 | Ricoh Aficio 2035 Copier
Printer won't pick up the paper even when the
have an expert look at it and do the servicing for you
Nov 21, 2009 | Canon ImageCLASS MF4350d Laser All-in-One ...
Feeds ok from tray 1 but not tray 2 which is 11x17. There are slight buffed marks at on the papaer in 4 spots but paper wont advance. marks are about 1/4 inch long
those marks are the rollers trying to move the paper. check to see if your tray 2 is lifting.if it is then replace the feed rollers.
Sep 28, 2009 | HP LaserJet 4mv Printer
Change papaer size and frequent papaer jams
OK it seems to be a problem with pick up clutch and vertical feed rollers ( When you open the left door and hinge in level of cass you will see axis with the tree little rollers- clean it with alcohol or water).Pick up clutch is better to replace it FK2-1068 (europe code).
Jan 12, 2009 | Canon iR 2016i Black and White Copier
HP 4250 down (paper jam without paper)
hi,
the fuser of that unit is in the back, you can saw it by sliding out the back cover. you can pull it by unlocking the 2 lock on side of it..
try to locate the sensor of the fuser assembly.and also try to see if they pick up very well both tray 1 and tray 2..
hope it would help you..
Aug 05, 2008 | HP 4250 Monochrome LaserJet Printer
Hp 1300 with added papaer feed tray q2485a
I am a little unclear as to where the problem is but you should check the pick up rollers and make sure they are not smooth, there needs to be some grip to them. If that does not seem to be the problem then the gears may be out of alignment.
Dec 06, 2007 | HP LaserJet 1300 Printer
176 people viewed this question
efs_perpends
efs_perpends
Muntejaya Ginting
Muntejaya Ginting
