Gary, Standard height from the floor to the bulls eye on the dartboard is 68" inches (173 cm) and the distance from the front face of the board to the toe line should measure 93 1/4" (237cm).
Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info." http://www.pdc.tv/rules-of-darts Darts Dartboards and Dart Supplies Dart Brokers Dartboard setup
Female Ideal Weight - Above Average Height
The average height of a woman in the US is 5-foot-4. When considering the weight and height ratio, a 5-foot-5 woman should weigh between 113 and 138, 5-foot-6 between 117 and 143 and 5-foot-7 between 122 and 149. The weight and height ratios continue to increase at approximately 4.5 pounds at the low end and 5.5 pounds at the high end of the range, per inch of height. A 6-foot-tall woman's ideal weight range is 144 to 176 pounds and a 7-foot-tall woman's range is 198 to 242 pounds.
Male Ideal Weight -- Under 6 Feet Tall
Men have an ideal weight range similar to that of women, but their weights are higher per inch. A man who is 5 feet 11 inches tall has an ideal weight range of 155 to 189 pounds, which is significantly higher than the 140- to 171-pound range for women. Men under 6 feet tall can determine their ideal weight without consulting a height-to-weight ratio table by starting at 5-foot-11 and a weight of 155 to 189 pounds. Simply subtract 5 to 6 pounds per inch from the low of 155 pounds, and 6 to 7 pounds per inch from the high of 189 pounds. Thus, a 5-foot-5 man has a range of 122 to 150 pounds and a 5-foot-tall man has an ideal weight range between 95 and 117 pounds. Are There Ideal Weight and Height Ratios LIVESTRONG COM
You need to remember that 1 inch is exactly equal to 2.54 cm So 1 foot =12 inches =12*2.54 cm= 30.48 cm = 0.3048 m. With this value you can convert 216 feet in meters as follows 216 feet =216*0.3048 m= 65.8368 m.
