Samsung SMH9187 Microwave Oven Logo
A
Anonymous Posted on Dec 13, 2013
Microwave beeps then SE appears - Samsung SMH9187 Microwave Oven
Maytag model MMV4203 display shows SE
same thing as Samsung - shorted key - google manual
1helpful
Microwave started beeping with nothing in it now it says SE or 5E
These issues are usally due to a defective touchpad or control board. Troubleshooting would require disconnecting the touchpad ribbon cable from the control board to see if that made the problem go away.
1helpful
The microwave started flashing SE the display and beeps every once in a while
The "se" stands for shorted keypad. Pretty much the keypad on your microwave is fried. There\'s a wide range of ways it could\'ve happened but you have two options. You can either dissemble the microwave and order parts online for a replacment keypad or buy a new microwave.
1helpful
3answers
Samsung microwave SMH8165W displaying error code -SE- and continuously beeps.
SE means system error, the keypad has a short in the membrane, or the control board has issues.
1helpful
Samsung microwave child error/ turnd power off now se appears in window and does nothn when push buttons
SE indicates a short in the keypad membrane, the keypad control board will need to be replaced, a costly venture.
My SMH9151W Samsung Microwave displays a -SE- or a -5E- and will not operate. I unplugged over night and still will not operate
I had the same issue on a 2010 smh9151w samsung microwave after installing it and using it with no problem for 5 days. The second time we unplugged the microwave and turned the circuit breaker off and on we didn't reset the clock on the microwave so the display shows :0 and it has been working for 7 days straight now. Fingers crossed that this is a long term solution. Hope this helps. Thanks!
Kenmore Microwave -SE- code
I have the same problem with my microwave and i cant fix it help?
Microwave starts beeping, four times then displays SE
Sounds as if it may be getting hot look at the back and under the unit there will be a grid of sorts sometimes at the back and//or the bottom or side/s of the machine check to see if this is free of dust etc if not clean and try again remember microwaves can give a nasty bite//please switch off and unplug first..
Top Samsung Microwave Ovens Experts
ZJ Limited
ZJ Limited
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
