Question about Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher
Ge gdf520pgdoww dishwasher will not fill with water makes a sound
No water is going through the value and the pump makes a noise but no water.
5 Related Answers
Anonymous
SOURCE: bosch dishwasher model no SGS4002GB
check to see if you have water in the sump {base} of machine. if there is a leak,the limit will activate making it look as though its washing but it is really the drain pump.working. sort the leak out
Posted on Mar 27, 2008
Anonymous
SOURCE: drain pump and no water going in
This most likely is not a level switch problem. Take the kick plate off (after turning circuit breaker OFF), look down in the base off the dw and youll probably see some water. Use a wet vac or towel to remove all water. The drain pump will now shut off and unit should function normally. You can now run the dw with the kick plate off and using a flashlight look for leaks. The bosch dw has a float switch in the base, water will activate this switch which will shut off the water valve and only allow the drain pump to run....it thinks it has a leak!
Make sure the disposal is draining properly & drain hose is not kinked as these are the most common reasons for your problem.
Posted on Apr 20, 2008
Anonymous
  • 478 Answers
SOURCE: Bosch SHV46C
Replace the fill valve that sound is it trying to open
Posted on Mar 12, 2009
Anonymous
  • 162 Answers
SOURCE: Water won't pump out of Dishwasher.
if your hearing a hum then something is in a bind. i have found things as small as 1/2 inch of a toothpick being enough to hold an electric pump back. i suggest taking a very simplistic approach to this problem. find the obstruction and remove it. good luck.
Posted on Jan 29, 2010
heatman101
D. Floyd Kolb
  • 43501 Answers
SOURCE: my dishwasher wont fill up
Here is a tip that will help you to find out why water will not come into the dishwasher...
Dishwasher Trouble
No Water entering Dishwasher
heatman101
Posted on Feb 13, 2011
Ge dishwasher about 7 years old as soon as we start it we hear the water turn on to fill but it does not fill water it imeadily start draining
Hello
Water Not Flowing Properly
Check to see if the water source to your dishwasher is turned on and not blocked or clogged. Also make sure the water line between the dishwasher and water source is connected and free from blockage. The door has to be closed properly as well.
If your water pressure is low, you can adjust the water intake value on the dishwasher to allow more water to flow through.
There is an overflow detection device on the dishwasher, so if the machine detected that, it will shut down the intake pump and open the drain pump. If this is the case, you will need to call for service because if there is water in the machine it will have to be cleaned out. Remember to turn off the water source to prevent further damage.
Sep 12, 2011 • Dishwashers
The dishwasher is not filling with water and it makes a contant buzzing noise
Whenthe dishwasher is not filling, it is your water value not opening up on thedishwasher. The constant buzzing noiseyou hear is the value that is sticking not letting the water into thedishwasher.
Ge dishwasher dont wash
i think this is a simple answer;;your dishwasher has a piece of glass in the out pump or something else.remove and you will find it will be ok adriqan.;;;;
Jan 20, 2010 • Dishwashers
Running but not cleaning
Hi
Thanks for using FixYa. First of all please check the Water temperature by using a thermometer inside the dishwasher to measure the water temp. It should be as close to 125 degree F to 140 degree F as possible. Now try using the temperature boost feature if your dishwasher is equipped with this cycle feature and check if this will help your wash ability issues.
Now check the Powder soap by making sure that you store your soap in a dry environment and it is not stale and clumping together. Possibly try a different detergent like a liquid or gel. Also, make sure the dishes are loaded properly, or dishwasher is not overloaded.
To check the proper filling dishwasher will fill with water up to and around the heating element. If water is more below the heating element, you may have low water pressure or a problem with the fill valve. Try & listen if it sounds like it is spraying the water around with enough pressure.
For low water pressure, try to clean the screen at the entrance of the fill valve, sometimes the fill valve can fail and not allow the proper water into the dishwasher and may need to be replaced. And, check the spray arm and pump cover for splits or leaks. Also make sure that the water is draining and is not accumulated in the dishwasher, if it is in dishwasher then check for clogged drain hoses and drain pump.
Low water fills are a very common trouble maker with today's dishwasher.
Please do rate this solution and revert for further assistance.
Thanks
Rylee
Ge triton xl makes loud noise when filling with water - water pump proboem ? or other possible cause? easy fix?
GE Triton dishwasher loud noise after draining water. We started to hear a sustained and loud noise after water is drained. This noise is not heard during washing and draining times. What is wrong? Thanks a lot!
Dishwasher wan't fill with water
The water valve may look fine but the solenoid may not be opening to allow water in. You said that everything else works fine except no water supply to the dishwasher. This sounds like a bad soleniod valve. Check for continuity on the valve with an ohms meter after you start it. Be careful.
Bosch SHV46C
Dishwasher problems
The washer may be attempting to run dry. Many times on these washers, a person may open the washer and then go to another load. The washer gets stuck with a dry pump until the timer tells water fill valve to open. Easy test. Start on regular cycle ,slowly advance the timer. it will click until you here the fill start and water will fill until.....
Bosh dish waher
Does it make the same noise when it's just filling or just when the motor starts? Usually just filling the dishwasher opens a valve and doesn't run the pump. If it makes noise during filling the valve may be getting hot and shorting, or may have a loose connection, or air may be in the water supply line causing the valve to bounce. If it takes a long time to fill the filter may be clogged.
Bosch 18 in. SRS45E02 / SRS45E08 Exxcel Slim-Line Free-standing Dishwasher Logo
Top Bosch Dishwashers Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Michael Thomas
Michael Thomas
Are you a Bosch Dishwasher Expert? Answer questions, earn points and help others
