Question about Sylvania 6432TE 32" TV
Protected program ma
How do i get it off
I have recently bought a HUAYU RM-L1130+8 I have tried to set it up pressing the Samsung number 9 by pressing it for 6 seconds, but it still won't work is there a code or something I can use
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. The site has set-up code list & set-up procedure to many popular brand remote controls. The site has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Set-up code list to many brand remote controls also is given. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
https://homenol.blogspot.com/
https://remotesearch.blogspot.com/
https://electronicshelponline.blogspot.com/
https://electrohelponline.blogspot.com/
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device./
Apr 23, 2018 | Samsung Televison & Video
I have dish network they told me contact yall. A black screen comes up and says protected program by tv-ma. Plz let me know how to fix this my number is 9047389009 my email is [email protected]
Kristen timmons,
I wouldn't recommend posting your personal information in public view like that due to its sensitivity and would appreciate your efforts if you could please email me your account number at [email protected] so I can pull your information up and help you with that.
May 06, 2014 | Televison & Video
I have a ma audio hk-602sx and my protect light wont go off and somthing is clicking inside and as it clicks the protect light blinks.
Disconnect the speakers and then try it again...there may be a shorted speaker or wire if the amp comes out of protect after you disconnect the wires...if the amp stays in protect after you disconnect the wires then there is a problem inside the amp with the circuitry and it will need to get serviced by an electronic tech
Jan 23, 2011 | MA Audio HK602SX Car Audio Amplifier
Wat anti virus ll really protect ma computers though i use diff kinds of antivirus bt m nt sure of wat????
Here is a link to AVG antivirus for free. Make sure there are no other antivirus programs on the computer because it won't work. Here's the link
http://download.cnet.com/3001-2239_4-10320142.html?spi=f05dfb7b47e04e2afb5f9e1852341c73
Mar 14, 2010 | Lenovo 3000 Y410 Laptop
Our TV Sylvania blocks some progrfams on ch. 51
Go to the TV setup menu and look for the V-Chip settings. Turn it off altogether or if you have children you may want to just raise the block up to MA, R, or X rated programs
Jan 25, 2009 | Sylvania 6427TE 27" TV
Amplifiers
It sounds like you've got too little impedance on it. How are the speakers wired? Are they in series (one speaker per channel) or are they in parallel (speaker 1 neg wire hooked up to channel 2, and speaker 2 neg wire hooked up to channel 1)? Or do you have a single speaker bridged (pos wire on one channel, neg wire on the other)? Often, an amp going into protection is a result of too much current draw, which happens when you're running a 2-ohm load on an amp that isn't rated to handle that (many are only OK at 4-ohms, which you'd have with series wiring). Let me know how you have the speakers wired and we'll go from there.
Aug 04, 2008 | MA Audio EHO152 15" 5000 Watts Subwoofer...
MA Audio HK4000D please help me ?
Turn the system off and disconnect the speakers. Turn the system on. If the amp still goes into protection mode with no speakers connected, then most likely the output transistors are bad. If the protection light is off, hook up one sub at a time until you find the one that is causing the problem
May 21, 2008 | MA Audio HK4000D Car Audio Amplifier
HOW CAN I GET PROTECTED PROGRAM TV-PG OFF MY TV?
This problem is caused by your TV's V-chip setting.
To fix the problem:
Push the "Menu" button (on either the remote or the TV's fromt panel).
Use the "Channel Down" button to go to "V-CHIP SETUP"
Use the "Volume Up" button to select it.
In the V-chip setup screen, the rating that is selected by the user as viewable will allow that rating and only lower ratings to be viewed on that TV. (If TV-G) is selected, then any programs rated higher than TV-G will be blocked.
So, the easistway to get rid of any blocking is to set the rating to TV-MA (mature), and then any and all programs will be viewable on that set. Select "TV-MA" by hitting the "Volume Up" button after you have scrolled down to that rating with the "Channel Down" button.
Then hit "Menu" to exit out of the settings and saave your changes.
Jan 27, 2008 | Sylvania 6432TE 32" TV
32 inch sylvania tv
To fix the problem:
Nov 23, 2007 | Sylvania 6432TE 32" TV
Sylvania 6432TE 32" TV Logo
Top Sylvania Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
