Question about KitchenAid KCMS145J Microwave Oven
How do I remove the cover of kitchen aid KHMS2050SSS3
I need to replace the fuse
2 Related Answers
MicrowaveSvc
William Miller
  • 9179 Answers
SOURCE: How do you replace the fuse in a microwave oven.
Be sure the oven is unplugged or the breaker is off.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
If you don't find yours, or if you want to look at it without disassembling the oven, you can download it here.
You can also find helpful exploded view diagrams and order parts by entering your full model number from the tag on the oven here.
Let us know if we can help further.
Posted on Jun 06, 2009
SOURCE: FUSE REPLACEMENT, KITCHEN AID KHMS155LSS
open *** and follow the cable which come from the back you will see an enclosure with fuse inside. Remove the fuse and replace with an other one with same specifications
Posted on Mar 12, 2012
Kitchen Aid microwave over will not heat
Common cause of this problem is transformer fuse blown.check the fuse.if fuse is ok, then replace magnetron
Mar 02, 2015 | KitchenAid Microwave Ovens
Kitchen aid microwave will not heat
first check the fuse if cutoff, replace it. if ok, then check for any broken wire. if all connections are intact, then test the heating element for continuity, if no continuity, then the element is bad and needs replacement. try these steps
Jun 11, 2013 | Microwave Ovens
Kitchen aid ykhms147hss-1
It's likely a failed fuse or TCO (thermal cutout / thermostat)
Yours should have a "mini-manual" (technical sheet) hidden either behind the grille or control panel. It's very helpful in locating and testing components.
There is a video here here showing how to remove a typical over the range control panel assembly in under 5 minutes.
Accessing some components (especially the oven cavity thermostat) for testing and possible replacement will require you to remove the oven from the wall and take off the outer cover.
If so, the installation instructions are very handy, and it's best to have two people since the microwave can be heavy and awkward.
You can find exploded views and installation instructions here and your can order Kitchenaid parts from The Pros here.
Apr 27, 2013 | Microwave Ovens
Mar 11, 2012 | KitchenAid KHMS155LSS 1000 Watts Microwave...
Kitchen aid micro wave change fuse
Unplug, remove top, look under keypad, follow wires to circuit board, look for a silver rectangular capacitor, "may be under a plastic flap" discharge capacitor with a screwdriver across the 2 points, look for a small fuse near by in clips, remove and replace with same current rating, assemble before test because lethal voltages present when powered.
Mar 11, 2012 | KitchenAid KHMS2050SSS Microwave Oven
How do i replace the magnatron on a kitchen aid khms147kss
You would need to remove it from the wall, using the installation instructions here, review the safety information here, then remove the outer cover and discharge the high voltage capacitor.
Then you can swap the magnetron.
You can find links to helpful exploded view diagrams and part ordering help here.
I recommend that you bookmark that link to your favorites.We're happy to help you with free advice and we'd appreciate your thoughtful rating of our answer.
May 05, 2010 | KitchenAid KHMS147 Microwave Oven
Lightbulb burned out for microwave model # KHMS 1850SSS-0 Kitchen Aid Where can I purchase a replacement? Thank you, Carrie
Most home improvement stores and even some Walmarts/Chain grocery stores/Ace Hardware carry replacements. You will need to remove the cover from the microwave oven on most models unless your bulb is inside a protective cover inside the actual oven. Take the bulb with you when you go to make certain of a proper match. Be certain to unplug the oven if you need to remove the cover in any case.
Oct 13, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Burned out bulb on Kitchen Aid Microwave Model KBMC140
You will need to remove the oven from the wall and remove the outer cover.
If for some reason you don't have yours, you can download your owner's manual and installation instructions free from this page.
These models use halogen lamps. You must not touch halogen types with your bare skin, as the oils will shorten the bulb life.
You should be able to get one from a home center or local appliance parts store.
If you order it online (from the link above) it is part # 4375348.
Aug 04, 2009 | KitchenAid KBMC140HSS Convection/Microwave...
Just suddenly died while warming up my corn
If the unit has never had the fuse replaced I would say start here. Thats a long time on a fuse. if you need help replacing it let me know. DFD
Apr 19, 2009 | Microwave Ovens
Need to replace door handle on microwave made by kitchen aid
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Normally you have to separate the door panels (as shown in the attached photo) and then you'll see the previously hidden screws you need to remove.
Or you can watch a YouTube video (not a video I made) here that demonstrates how it's done.
We're happy to help and we appreciate your thoughtful rating of our answer.
Jul 07, 2008 | KitchenAid Microwave Ovens
KitchenAid KCMS145J Microwave Oven Logo
112 people viewed this question
Top KitchenAid Microwave Ovens Experts
William Miller
William Miller
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a KitchenAid Microwave Oven Expert? Answer questions, earn points and help others
