How do i replace Maytag Neptune front load washing machine bearings
I have a Maytag Neptune model # MAH21PDAWW and the washing machine bearings need to be replaced because it is noisy and the belt keeps falling off.. How do I replace these bearings? Any help would be greatly appreciated..
Posted by Robert Jacobs on
CountryJohn
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 77 Answers
The machine obviously must come apart. See this youtube video:
Posted on Jan 27, 2014
3 Related Answers
aborcass
Ron Coons
  • 2651 Answers
SOURCE: maytag Neptune front loader rubber boot replacement
can be done just need PATIENCE!.. youll need ot remove the door assembly, and the 2 screws oppisirethe heing willalow for the front "u" shaped panel to be reomved.. next remove the 4 screws from with in the dispenser area, and then there are perhaps (6) 5/16 screws holding the nextfront bulkead and maintop assy down.. after removing theese screrws youll be able to lift eh main top back wards( prop it with something, a few more screws will release te hlatch assembly.. from here you can probably install the new bellow, remove the spring and wire, and the work the new bellow around the tub lip. a third hand will come in handy, after working it around , youll needto reconnect the tension spring..HARDEST PART OF JOB>>> REQUIRES PATIENCE!!!!!. sometimes this goes on for me with out issue in 5 min, other times 25 min and im PISSED AT IT!!!!!!!,, wrap the wirer around bottom of lip and your going to hold one end of spring, needlenose vice grips work perfectly. then with another set of needle nose. stretchthe spring togethr to lock the wire around.. whern you finally get this reassemble the latch and drop the top back down replace all teh screws, and finally you need to retuck the bellow into the front bulkhead( tabbs line it up nicley.. good luck!!!
Posted on Feb 22, 2009
Anonymous
SOURCE: replacing door gasket on maytag neptune MAH5500BWW washer
I need to know what are the steps to replacing the door gasket, I would like to know what to take apart, and what not to take apart. Like a step by step lay out.
Posted on May 25, 2009
barkencoa
Barry Coates
  • 3463 Answers
SOURCE: Noisy spin on hotpoint aquarius WF530 6kg washing machine. Suspect bearing how do I replace them.
If you spin the drum by hand, and it is niosy and rumbling then the main drum bearings have failed.
If under 5 years old, then you should be able to get it repaired under Hotpoint 5 year guarantee, You just pay for labour and call out, cheapest option, it is not really a D.I.Y job, as it is quite involved, and entails a lot of work.
Please rate my advice.
Thanks.
Posted on May 27, 2009
Noisy front load maytag washer
Center bearing going bad,Maytags have a history of this and the whole tub will have to be replaced cause the bearing is made no to come out and.it's best to get a extended warranty on all Maytags,the repairman is so busy now days.
Feb 16, 2013 | Maytag Neptune MAH5500B Front Load Washer
Maytag neptune washer noisy when in spin cycle. also there's a small hole located in the back of the machine on the drum with metal shavings coming out of it. The noise is a loud grinding noise. could...
You have a bad rear bearing in the outer tub. The entire outer tub would need to be replaced to resolve this issue.
Check your owner's manual to see what kind of warranty you have on this part. I'm keeping my fingers crossed for you as this is an expensive repair!
Good luck!!
Jun 16, 2010 | Maytag Neptune MAH5500B Front Load Washer
Maytag Neptune TL clutch problems- Class Action Lawsuit??
I sounds like this is a common problem with the Maytag Neptune TL after about 3-5 years. Mine finally went out yesterday after several months of bearings getting louder all of the time. It looks like the bearings and the controller are gone. What happened to washing machines that last 15 - 20 years?
Dec 07, 2009 | Maytag Washing Machines
Neptune MAH5500 Neptune has progressively gotten louder on spin. Very loud noise sound like bearing going. Continues to get worse. Can it be fixed or too expensive to justify?
Hi.
If you get a very loud noise coming from the machine, and this noise is louder when it spins faster, then it is often because of a problem with the drum bearing.
The drum bearing is bad, Check if the drum has excessive play.
To replace the part you take apart machine, undo the belt and depending on the model you may need to remove more parts.
To get a quote on repair call Maytag at the number listed on the owner manual, the machine may still be worth repairing.
You can find parts and diagrams for most models here.
Nov 14, 2009 | Maytag Neptune MAH5500B Front Load Washer
Noisy during spin cycle
This may be due to a worn belt (squeeks when changing speed), Faulty dampers - (banging about), constant rattling (rear bearing), or a motor on it's last legs (replace motor).
Most faults can be fixed by replacing those listed.
Sep 29, 2009 | Maytag Neptune MAH5500B Front Load Washer
The main bearing is very loose, causing the belt to fall off.
Call a appliance store that handles Maytag with the model number a get a replacement they are not adjustable
Aug 26, 2009 | Maytag Neptune Washer
Maytag Neptune MAH3000AWA seems to be rubbing
I suspect that you have a leveling bracket come loose. Many of the Maytag washers also use a large concrete block fastened underneath to help balance things. Look to see if yours is this type. If so then the steel rod holding thinge that holds it in place may have come loose...should be easy to put back correctly but will require some muscle. Most of the Sears Kenmore units have springs that can come loos from their connections and require re hooking but I do not think you have this type of unit for a Maytag. Hope this helped.
Aug 21, 2009 | Maytag Washing Machines
My indesit washer belt keeps falling off what shal i do?
AHi, firstly, is the machine very noisy when it spins? Does the inner drum feel loose ie. can you waggle it about? If the answer to these is yes, then the machine bearings will need replacing which could get expensive. If however, the drum sounds normal when it spins and it spins quite freely when you spin it by hand, then the belt just needs replacing. The newer machines use non adjustable stretch belts which are known to stretch over time and then start falling off.
Jun 05, 2009 | Washing Machines
Belt keeps coming off the pulley
I suggest you check your drum bearings, belt will only come off if misaligned.
Mar 09, 2008 | Maytag Neptune MAH5500B Front Load Washer
Washing Machines Logo
76 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
Marvin
Marvin
