Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE Profile White 26.6 cu ft No-Frost Refrigerator (TFX27PF) manual
4 Related Answers
MNTECH
Carl Schulzetenberg
  • 1543 Answers
SOURCE: Ice maker only makes crushed ice
Pull the ice bucket out. Behind it you will see a rectangular hole with a rod in it. The rod should be able to move with your one finger up and down. If it does not, the solonoid attached to it is either frozen or burnt out.
Posted on Nov 25, 2008
Anonymous
  • 8 Answers
SOURCE: Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Posted on Mar 25, 2010
Sal De
  • 2699 Answers
SOURCE: We have a GE 22.2
if there's frost on the back inside wall of the freezer and the fridge is getting warm you have a defrost problem,or if frost is on packages and racks the door could of been left open or the door where the ice comes out might not be closing properly.if it's a defrost problem you could have a bad defrost fan motor,you wouldn't hear the fan turn on when you open the freezer door,a bad timer or board,you didn't send the model number,bad heater or thermostat or loose wire.
Posted on Apr 09, 2011
cyrus_mansoo
cyrus_mansoo
SOURCE: My side by side 23.6 cu. ft. no frost refrigerator is not freezing and the refrigerator is not getting cold enough. There's frost on the back wall inside freezer. It's a GE TFX24VR. What can I
usually that means your fridge thermostat is being blocked by items in your fridge, telling the cooling system to shut down. If your fridge and freezer are packed, the fridge might protect itself by shutting down the cooling system. Happened to us last Thanksgiving.
Posted on Mar 08, 2012
Defrost light flashing on my TFX27PF
Ordinarily, that's an indication that the automatic defrost function has failed. If not corrected, the evaporator coil will eventually ice up and cause the freezer temperature to rise.
On older models, the most common cause is a worn out defrost timer. Easy to replace and not particularly expensive.
On newer electronically controlled models, expect to replace the (Chinese made) motherboard. Expensive, and the replacement won't be any better quality than the original.
Mar 13, 2014 | GE Profile 26.6 cu. ft. Side-by-Side...
I need the part number to replace ice maker in GE Profile TFX27PF or TFT27PF
The replacement part number is WR30X10093 it is GE's newest electronic icemaker,all newer style icemakers and designed to also work for older models such as yours
GENE
Sep 17, 2011 | GE Profile 26.6 cu. ft. Side-by-Side...
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Freezer frost
Make sure that the evaporator fanmotor is working.
Nov 06, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Fridge is warm and freezer is cooler than normal
Possible bad defrost timer. Locate timer underneath the fridge and manually turn the knob. Element should come on and start defrosting. If defrosting starts then the timer is bad. Check also the element and thermostat.
Jul 05, 2009 | GE Profile 21.6 cu. ft. Top Freezer...
Warm temp
u have a defrost problem if u shut it down 4 or 5 hrs with doors open then turn back on itll work tii u have it fixed
Mar 24, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
GE TFX27PF refrigerator and freezer still not getting cold enough
the partial frost pattern is an indication of low refrigerant, restriction or bad compressor. if the unit is under 5 years old this repair will probably be under warranty thru GE. if out of warranty then you are looking in most cases between 200-500 dollars for repair. good luck Thanx peyton
Jan 30, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
613 people viewed this question
Top Refrigerators Experts
Ron Rak
Ron Rak
gbob59
