Behringer Eurolive B212A Speaker Logo
Sean Jermaine Posted on Dec 12, 2013
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I open my b212a and disconnected the speaker and horn wires and know i have completed my repair i am read to reconnect and i don't remember which set of wires are the positive side
Serge Lavallee
Level 2:
New Friend:
Cheetah:
An expert who has answered 20 or more questions within one hour.
  • Expert 75 Answers
  • Posted on Oct 13, 2014
Serge Lavallee
Expert
Level 2:
New Friend:
Cheetah:
Answers
75
Questions
5
Helped
28854
Points
200
You should have plug output for woofer and tweeter. First. Output plugs should be named like : X3(1): + Woofer X3(2): - neg. Woofer and for the tweeter: X3(4) + Tweeter and X3(3) - neg. At least, that is the wiring for the model : B215A. With a little luck, you should get something around the same. Also try wiring coming from the small i think 15 pin IC (Tweeter), if you can follow the trace on the board that go to the 15 pin IC. This is the tweeter output + and -. And the 2 other bigger may be from the big Output transistor. Best of luck! Serge Lavallee.
  • Serge Lavallee Oct 14, 2014
    I think the number of the IC is: LM3886, 11 pin out. Best of luck! Serge Lavallee.
Luis Oquendo
Level 1:
Problem Solver:
  • Contributor 4 Answers
  • Posted on Jan 16, 2014
Luis Oquendo
Contributor
Level 1:
Problem Solver:
Answers
Questions
Helped
8544
Points
I have one europolive b 215a wrong ic twiter ineed number to ic twiter for remplace
Don Wallis
Level 2:
Scholar:
New Friend:
  • Expert 67 Answers
  • Posted on Dec 14, 2013
Don Wallis
Expert
Level 2:
Scholar:
New Friend:
Answers
67
Questions
0
Helped
21867
Points
116
Because the system is bi-amplified, it is important to replace the wires correctly to avoid phase problems. I don't know how the wires are colour coded, but if it is any help I downloaded the schematic and the wires are numbered 1: Woofer Active 2: Woofer Earth
3: Tweeter Earth and 4: Tweeter Active. Sorry if that's no help. Otherwise it should be easy to trace the wires to see which connect to earth.
1 Related Answer
Steve Mason
  • 311 Answers
  • Posted on Dec 13, 2013
SOURCE: I open my b212a and disconnected the speaker and horn wires and know i have completed my repair i am ready to reconnect and i don't remember which set of wires are the positive side
strictly speaking speaker wires are not 'live' they have a + and - but no electricity flows down them. easy to test. i am assuming the wires do not have connectors on the ends, just bare wires. put the wires into sound system as normal and hold the other ends on the terminals in the speaker, if there is poor or no sound, swap them over. you will definitely know when you have it right.
No sound , display shows digital protect
The most common problem found on FixYa for Audio Video2_bing.gif Receiver's is:
My receiver say's "Protect" or turns on then off. What's wrong? Seven times out of ten it is a shorted speaker or speaker wire. To determine your exact problem, the first step is to disconnect all speaker wires "at your receiver" Next: Turn the receiver back on. If your receiver still says "protect" or turns off, it needs to be serviced. If your receiver stays on; reconnect your speakers one at a time and power back up after each speaker. You may find that after reconnecting all speaker wires it works! Most commonly the small braids of wire from the + to the - have touched and have caused the problem. In some instances, you noticed the problem only when turning the volume up. either way, make sure the exposed wires to your receiver are no longer than 1/2" long and are completely under the screw down terminal or slide in. When you've found the wire or speaker with the problem, your receiver will go back into "protect" At this point, disconnect the wire from the speaker at the speaker that may be causing the problem then test again.* Note* Make sure speaker wires do Not touch each other as this Will cause a short! If you turn the receiver back on and it stays on, you now know the problem is in your speaker itself. To test your speaker, you will need a multimeter. Set it to ohms resistance and touch the speaker terminals, if there is a short internally the meter will read "1......" If it's an analog meter, it will peg to the right. There's your problem. Now, within any speaker there are quite a few possibilities as to what could be causing the problem. Most common is a blown coil and the speaker needs to be replaced. Some speakers have internal crossovers (usually floor standing speakers) and may have a shorted or burnt board (usually very visible brown burn marks on the board) and can possibly be repaired if your handy with a soldering iron. Now, if you disconnect the speaker wire at the speaker and it still says "protect" Check your wire for the obvious cut or nail thru the wire if possible. If your system has wiring that runs behind walls, you may need to use your meter again. Disconnect the wire at both ends, keep the ends separated, put your meter on ohms resistance and touch probes to the + and - wires at one side. If the meter pegs to the right or reads "1...." the wire is shorted and needs to be replaced or repaired at the short. Hope this helps.
2helpful
Onkyo TX NR807 goes into protection mode when swapping music DSP settings (e.g., THX, surround etc.) Works fine for all movie settings
The most common problem found on FixYa for Audio Video Receiver's is:
1helpful
Sorry what's SP CABLE WHERE I CAN FIND IT?
"Sp Cable" is referring to Speaker Cable. Read thru this, hope I'm on the right track for you.The most common problem found on FixYa for Audio Video Receiver's is:
Hi! Brand new unit - bought 1.5 years ago - never opened the box (such an idiot I am) I have a use for it not but it doesn't work. Press power on - I hear a click an dthat's it - nothing lits up. I uppan -...
1helpful
I am getting an "OVERLOAD" message on my unit. It keeps turning on and off. The unit only works on a very low volume setting.
1helpful
2answers
Behringer 212A, lost its highs, is there a way to test the horn vs the driver circuit? = Duane
Hi duane
To answer your question;
Usually you would use an ohm/impedance meter or multimeter to test the voice coil right at the horn`s terminals then with the crossover network connected you would go down the line all to the speaker box terminals to check for an open line.
But if you don`t have a multimeter you can rig a small AAA battery with two wires connected and listen for a "click" sound as you touch and release the horns terminals.
Of course this would only tell you if you have an open voice coil but it is often enough.
Hope this help Good luck
1helpful
Rxv1700 power will not stay on
Disconnect all speaker wires at the receiver then turn on, if it still turns back off, it needs to be serviced. Must have had a power spike or drop. Repair cost ranges from 200-300.
1helpful
The unit turns on then shuts off after a few seconds.
This could be a bad speaker or speaker wire. I had this same problem recently. In my case it was the powered sub-woofer. I disconnected the speaker wire from the back of the receiver(with the power off, of course). When I powered up the receiver, problem solved, it worked fine. I then made sure the wire was not shorting out, carefully reconnected everything and the sub works too. I never found the cause, but it has worked fine for several months now.
You can start by disconnecting all the speakers. If the receiver powers-up reconnect them one at a time to find the bad wire/speaker. If it is not the speakers, disconnect all attached devices. If the receiver still won't power-up go shopping for a new one. It is not worth repairing. It is less expensive to replace it.
Remember, always turn the power off and set volume to zero before disconnecting or connecting anything! You don't want to cause any damage.
Blown horn
Remove blown horn speaker and take it to a electronic shop and asked them to check with special speaker meter to see the condition of speaker widings.
Top Behringer Audio Players & Recorders Experts
 Grubhead
Grubhead
SmartAviator
SmartAviator
ADMIN Andrew
ADMIN Andrew
Are you a Behringer Audio Player and Recorder Expert? Answer questions, earn points and help others
